BT.com
Wishlist
NewStar LCD/TFT desk mount
Delivery
Standard Due date unavailable
The NewStar desk mount FPMA-D935G allows you to attach a LCD/TFT screen up to 26" on a desk. With this mount you can easily swivel, tilt and rotate the monitor. It has 3 pivots. The height adjustment of 50 cm can be changed manually. The desk mount can hold screens up to 12 kg and is attached on a desk by a grommet. The arm length is 50 cm. This model is suited for all LCD/TFT screens with a VESA 75x75 or 100x100 mm hole pattern. By using an ergonomic monitor arm you prevent neck- and back complaints. Ideal for use in offices and on counters or receptions.
NewStar FPMA-D935G - desk mount
Desk mount
Adjustable Depth
12-50 cm
Adjustable Height
0-50 cm
Tilt
Recommended Use
LCD display
Recommended Display Size
10"-26"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
12 kg
Silver
5 years warranty
Adjustable Depth
12-50 cm
Adjustable Height
0-50 cm
Silver
AV Furniture
Desk mount
Mounting Components
Articulating arm, grommet mount, desk mount
Recommended Use
LCD display
10"-26"
Tilt
Max Load Weight
12 kg
Adjustable height, adjustable depth, rotating, swivel adjustment
Limited warranty - 5 years
Scroll to top
