BT.com
Wishlist
NewStar Generic Newstar Flatscreen Desk Mount 10-26" Clamp 1 Screen
NewStar Generic Newstar Flatscreen...
£73.41
38 in stock
£73.41
Add to wishlist
Delivery
Standard 3-5 working days
The NewStar desk mount FPMA-D960 allows you to attach a LCD/TFT screen up to 26" on a desk. With this mount you can easily swivel, tilt and rotate the monitor. It has 3 pivots. The height adjustment of 45 cm can be changed manually. The desk mount can hold screens up to 12 kg and is attached on a desk by a clamp. The arm length is 43 cm. This model is suited for all LCD/TFT screens with a VESA 75x75 or 100x100 mm hole pattern. By using an ergonomic monitor arm you prevent neck- and back complaints. Ideal for use in offices and on counters or receptions.
NewStar Full Motion Desk Mount (clamp) for 10-30" Monitor Screen, Height Adjustable - Black - mounting kit (Tilt & Swivel)
Mounting kit (Tilt & Swivel)
Mounting Components
Articulating arm, desk clamp mount
Adjustable Depth
10-43 cm
Adjustable Height
0-45 cm
Tilt
Recommended Use
LCD display
Recommended Display Size
10"-26"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
12 kg
5 years warranty
Adjustable Depth
10-43 cm
Adjustable Height
0-45 cm
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
LCD display
10"-26"
Tilt
Max Load Weight
12 kg
Adjustable height, adjustable depth, rotating, swivel adjustment
Limited warranty - 5 years
Scroll to top
