BT.com
Wishlist
NewStar Flatscreen Wall Mount 23-60" 1 screen Tilt Vesa 7
NewStar Flatscreen Wall Mount...
£55.63
Hurry, only 2 left in stock!
£55.63
Add to wishlist
Delivery
Standard 1-3 working days
The NewStar PLASMA-W240, allows you to mount a LED/LCD/Plasma TV to any wall. Cause of the flexible hole pattern of this system is this wall mount useable for almost every TV up to 52 inches. This wall mount allows users to tilt screens up to 20 degrees. This wall mount is easily to install by using the VESA hole pattern at the rear side of your TV. This wall mount can be used when the maximum distance between the holes (left to right) is 40 cm. The upper and lower holes allow a maximum distance of 40 cm. The PLASMA-W240 is made of aluminum and is mountable to any wall. Including security lock.
NewStar TV/Monitor Wall Mount (tiltable) for 23"-60" Screen - Blac - wall mount
Wall mount
Tilt
Recommended Use
LCD / plasma panel
Recommended Display Size
23"-52"
Flat Panel Mount Interface
75 x 75 mm, 400 x 400 mm
Max Load Weight
50 kg
Material
Aluminium
5 years warranty
Material
Aluminium
AV Furniture
Wall mount
Mounting Components
Tilt wall mount
Recommended Use
LCD / plasma panel
23"-52"
Tilt
Max Load Weight
50 kg
Limited warranty - 5 years
Scroll to top
