BT.com
Wishlist
NewStar Flatscreen Monitor Desk Mount
NewStar Flatscreen Monitor Desk...
£112.88
Hurry, only 3 left in stock!
£112.88
Add to wishlist
Delivery
Standard 1-3 working days
The NewStar desk mount, model FPMA-D960DG is a tilt-, swivel and rotatable desk mount for 2 flat screens up to 26". This mount is a great choice for space saving placement on desks using a grommet mount.
NewStars' unique tilt (180°), rotate (360°) and swivel (180°) technology allows the mount to change to any viewing angle to fully benefit from the capabilities of the flat screen. The mount is manually height adjustable from 0 to 45 centimeters. A unique cable management conceals and routes cables from mount to flat screen. Hide your cables to keep the workplace nice and tidy. NewStar FPMA-D960DG has three pivot points and is suitable for screens up to 26" (65 cm).
NewStar Full Motion Dual Desk Mount (grommet) for two 10-27" Monitor Screens, Height Adjustable - Black - mounting kit
Mounting kit - desk-mountable
Mounting Components
Grommet mount, pole, 3 pivots, 2 mounting arms
Adjustable Depth
10-43 cm
Adjustable Height
0-45 cm
Tilt
Recommended Use
2 LCD displays
Recommended Display Size
10"-26"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
12 kg
5 years warranty
Adjustable Depth
10-43 cm
Adjustable Height
0-45 cm
AV Furniture
Mounting kit
Mounting Components
Recommended Use
2 LCD displays
Placing / Mounting
Desk-mountable
10"-26"
Tilt
Max Load Weight
12 kg
Rotating, swivel adjustment
Limited warranty - 5 years
Scroll to top
