BT.com
Wishlist
NewStar Flatscreen Desk Mount 10-24"
NewStar Flatscreen Desk Mount...
£50.65
13 in stock
£50.65
Add to wishlist
Delivery
Standard 3-5 working days
The NewStar desk mount FPMA-D400 allows you to attach a LCD/TFT screen up to 24" on a desk. With this mount you can easily swivel, tilt and rotate the monitor. The height adjustment is 40 cm. The desk mount can hold screens up to 10 kg and is attached on a desk by a desk clamp. The arm length is 34 cm. Cables can be placed in the column. This model is suited for all LCD/TFT screens with a VESA 75x75 or 100x100 mm hole pattern. By using an ergonomic monitor arm you prevent neck- and back complaints. Ideal for use in offices and on counters or receptions.
NewStar FPMA-D400 - adjustable arm
Adjustable arm - desk-mountable
Mounting Components
Articulating arm, desk mount, clamp
Adjustable Depth
10-34 cm
Adjustable Height
0-40 cm
Tilt
Lift
40 cm
Recommended Use
LCD display
Recommended Display Size
10"-30"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
10 kg
Grey
5 years warranty
Adjustable Depth
10-34 cm
Adjustable Height
0-40 cm
Grey
AV Furniture
Adjustable arm
Mounting Components
Recommended Use
LCD display
Placing / Mounting
Desk-mountable
10"-30"
Tilt
Lift
40 cm
Adjustments
Height, tilt, swivel, rotation
Max Load Weight
10 kg
Adjustable height, rotating
Limited warranty - 5 years
Scroll to top
