BT.com
Wishlist
NetGear WC7660SKT Premium Wireless Controller Bundle
Delivery
Standard Due date unavailable
The NETGEAR ProSAFE WC7600 Premium Wireless Controller is a fully featured enterprise class, high performance and secured wireless controller capable of managing up to 150 Access Points and 6,000 concurrent clients per cluster. The WC7600 delivers ultra-fast Access Point discovery, Layer 2 and Layer 3 fast roaming, multiple 10 Gigabit connectivity, a captive portal for guest access, fully distributed architecture, and ease of configuration and management.
Unlike other Wireless systems that are costly, complex and cumbersome to deploy, the WC7600 wireless controller is ideal for K-12 education, hospitality, and healthcare deployments. Designed with simplicity in mind for management and ease of use, it offers enterprise grade functionality and capability for small to mid-sized organizations, without the cost and complexity of big IT.
NETGEAR ProSafe WC7600 Premium Wireless Controller - network management device
Network management device
External - 1U
United Kingdom
Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet
AC 100/230 V
Power Redundancy
44 cm x 43 cm x 4.3 cm
7.57 kg
NETGEAR lifetime warranty
Height (Rack Units)
1U
44 cm
43 cm
4.3 cm
7.57 kg
United Kingdom
External
Wired
Remote Management Protocol
SNMP 1, SNMP 2
Status Indicators
Status, link/activity, fan
Auto-sensing per device, auto-negotiation, load balancing, stackable, IPv6 support, Wi-Fi Multimedia (WMM) support, RADIUS support, DHCP server, IPv4 support, rogue access point detection
Encryption Algorithm
AES, TKIP, WPA, WPA2, WEP
Authentication Method
Radio Service Set ID (SSID), LDAP, Active Directory
IEEE 802.1x, IEEE 802.11i, IEEE 802.11e
2 x 10Gb Ethernet - SFP+ , 1 x 1000Base-T (management) - RJ-45 , 1 x management - DB-9 , 1 x USB 2.0 - Type A
MTBF
664,072 hours
Installed Qty
2
Max Supported Qty
2
Power Redundancy
AC 100/230 V
165 Watt
45 °C
10 - 90%
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.62
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£19.63
£13.69
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.54
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£17.96
Resources
The following resources are available for the NetGear WC7660SKT Premium Wireless Controller Bundle
Scroll to top
