BT.com
Wishlist
NetGear UTM25S - ADSL Bundle Web Email & Web Subscription
Free delivery
Delivery
Standard Due date unavailable
The ProSecure UTM series of all-in-one gateway security appliances combine best-of-breed security technologies and Stream Scanning technology to protect businesses against today's web, email, and network threats. Malware hosted on web pages, phishing attacks, spam, virus infected emails, hackers, denial-of-service attacks, and other threats are now all part of a regular repertoire of sophisticated blended attacks that bypass traditional firewalls with ease. Growing businesses have been the ones most seriously affected as they, unlike their enterprise counterparts, often lack the time and resources to fully harden and secure their networks from these threats.
ProSecure Unified Threat Management (UTM) appliances combine performance with comprehensive security coverage. Stream Scanning technology enables the use of an extensive virus and malware database while maintaining a high level of throughput and minimizing scanning-induced latency. The flexible modular software design architecture leverages Stream Scanning technology to scan files and data streams up to 5x faster than conventional methods. This architecture, combined with best-of-breed hybrid in-the-cloud web filter and anti-spam technologies along with proven firewall and VPN functionality, form the ideal growing business gateway security solution.
Given the high performance requirements of scanning latency sensitive web traffic, incorporating enterprise-grade security software technologies onto traditional all-in-one platforms has been a very difficult task. That is why the ProSecure UTM features Stream Scanning technology which analyzes data streams as they enter the network. The ProSecure Stream Scanning approach is many times faster than that of more traditional batchbased scanning methods where the entire file is buffered before it is scanned. Due to its nature, traditional batch-based scanning methods introduce latency to network traffic. While latency is more tolerable for email traffic, for large amounts of HTTP web traffic, such latency often slows web browsing to a crawl. All-in-one solutions in the past have tried to overcome the latency issue by minimizing the malware signature set, scanning only a handful of file types, or by avoiding web traffic scanning altogether. This approach exposes an entire vector of the network to malware-based.
NETGEAR ProSecure Unified Threat Management Firewall UTM25S - security appliance
Security appliance
External - 1U
Europe
RAM
1 GB
Flash Memory
2 GB
Performance
Firewall throughput: 980 Mbps , Application throughput: 905 Mbps , Antivirus throughput: 25 Mbps , IPS throughput: 240 Mbps , Unified Threat Management (UTM) throughput (HTTP traffic): 24 Mbps , Unified Threat Management (UTM) throughput (non-HTTP traffic): 240 Mbps , VPN throughput: 90 Mbps
Concurrent connections: 40000 , Virtual interfaces (VLANs): 255 , Malware signatures: 1200000 , Maximum number of users: unlimited , Applications protected: 1212 , IPS signatures: 2114 , IPSec VPN tunnels: 25 , SSL VPN tunnels: 14 , PPTP VPN tunnels: 5
VoIP Protocols
SIP
AC 120/230 V ( 50/60 Hz )
33 cm x 28.6 cm x 4.3 cm
2.56 kg
Security appliance
Height (Rack Units)
1U
33 cm
28.6 cm
4.3 cm
2.56 kg
Europe
Processor / Memory / Storage
RAM
1 GB
Flash Memory
2 GB
External
Wired
Network / Transport Protocol
PPTP, PPPoE, SMTP, FTP, POP3, IMAP
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 2c, HTTP, HTTPS
Performance
DMZ port, NAT support, VPN support, PAT support, load balancing, VLAN support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, Intrusion Prevention System (IPS), anti-spam protection, anti-malware protection, Quality of Service (QoS), DHCP server, DHCP relay
Encryption Algorithm
DES, Triple DES, MD5, IKE, SHA-1, TLS 1.0, SSL 3.0, PKI, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, LDAP, Active Directory
IEEE 802.1Q
IP Telephony
VoIP Protocols
SIP
4 x 1000Base-T - RJ-45 , 2 x 1000Base-T - RJ-45 ( WAN ) , 1 x USB
Rack Mounting Kit
Included
VCCI, cUL, RoHS, WEEE, FCC Part 15 A, C-Tick Class A
Internal power supply
45 °C
0 - 90%
Scroll to top
