BT.com
Wishlist
NetGear RangeMax Wireless-N Gigabit
Delivery
Standard Due date unavailable
Fully compatible with major DSL Internet service providers.
Push 'N' Connect using Wi-Fi Protected Setup™ (WPS) allows you to add computers to the network quickly and securely.
ReadyShare™ provides fast and easy shared access to an external USB storage device.
-Higher speed and range with Wireless-N technology for gaming and video streaming.
-Gigabit Ethernet ports deliver ultra-fast wired connections.
-ReadyShare™ provides fast and easy shared access to an external USB storage device.
-Built-in ADSL2+ modem for use with DSL broadband (through the telephone line).
NETGEAR RangeMax DGN3500 - wireless router - DSL modem - 802.11b/g/n (draft 2.0) - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Remote Management Protocol
HTTP
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, Wi-Fi Protected Setup, IEEE 802.11n (draft 2.0)
22.3 cm x 15.3 cm x 3.1 cm
0.5 kg
UNIX, Apple MacOS, Linux, Microsoft Windows 2000 / ME / XP/ Vista
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
HTTP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
Firewall protection, DMZ port, DoS attack prevention, Intrusion Detection System (IDS), parental control, Quality of Service (QoS), Wi-Fi Protected Setup (WPS)
Status Indicators
Port status, power, link OK
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.992.1 (G.DMT) Annex A
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / DMZ: 1 x ADSL2+ - RJ-11 , USB: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
3
External power adapter
Vertical stand, POTS filter
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
22.3 cm
15.3 cm
3.1 cm
0.5 kg
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* DGN3500
Reviewed by David on 20/02/2011
Replaced a 6 year old DG834G. Seems to work well - setup was very straight forward, connection not dropped once after 3 days use, wireless range significantly improved. uPnP worked first time with my IP camera. Overall, very pleased.
Only other comment - Netgear currently seems to have a rather confusing branding/naming/product line strategy. Every product seems to have 2 different names these days. This one, for instance, is called "N300 Wireless Gigabit ADSL2+ Modem Router - Work and Play", but they also add the old style name, "DGN3500". The Netgear website is no real help either - lots of products with nearly identical names, and nearly identical functions. It all needs a good clear out....
5* DGN3500
Reviewed by David on 07/11/2012
Bought this a month ago. Dead easy to setup and upgrade the operating system. Use it for AOL with wireless for the laptop. Rock solid with ISP and wireless. Very pleased with purchase.
2* DGN3500
Reviewed by David on 27/05/2011
Update since my review in Feb. Occasionally, the modem loses connection. That’s fine, and possible on any modem. What isn’t acceptable is that the modem won’t automatically reconnect – you have to log into the router, and push “connect” in the status menu. Seems this is a known issue (for over a year), but Netgear haven’t fixed it Won’t be buying Netgear again – not because of this problem (any product can have a s/w issue), but because Netgear don’t appear to fix well known issues in a timely fashion. I recommend you look elsewhere.
Scroll to top
