BT.com
Wishlist
NETGEAR RangeMax Dual Band Wireless-N For Cable Users
Delivery
Standard Due date unavailable
The NETGEAR RangeMax Dual Band Wireless-N Gigabit Router delivers the ultimate in wireless performance for home and small business networking. With twice the available bandwidth, separate Wireless-N access points for media/gaming and data, and concurrent dual band N, you will enjoy the most reliable wireless connections for HD media streaming, gaming, and maximum Internet bandwidth. Along with four gigabit Ethernet ports enabling maximum wired speeds, this full featured high performance router is an ideal solution for the connected home with multiple computers and network enabled gadgets running multiple applications at the same time.
Centralizing an external storage device and file sharing is easy. Simply connect your USB storage device to the back port of your Dual Band router, and every computer on your network can now access the USB Storage device, easily exchanging media, documents, music, and more. The dual band gigabit router prioritizes network traffic efficiently, ensuring high quality of experience for video streaming, VoIP, online gaming and other critical tasks.
NETGEAR RangeMax WNDR3700 - wireless router - 802.11a/b/g/n (draft 2.0) - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Remote Management Protocol
HTTP
Firewall protection, Stateful Packet Inspection (SPI), DoS attack prevention, Quality of Service (QoS), Wi-Fi Protected Setup (WPS)
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0)
Environmental Standards
ENERGY STAR Qualified
22.3 cm x 15.3 cm x 3.1 cm
0.5 kg
Microsoft Certification
Compatible with Windows 7
UNIX, Apple MacOS, Linux, Microsoft Windows 2000 / ME / XP/ Vista
United Kingdom
1 year warranty
Enclosure Type
Desktop
Wireless, wired
HTTP
Encryption Algorithm
WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
Radio Service Set ID (SSID)
MIPS 680 MHz
RAM
64 MB
Flash Memory
8 MB
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
8
External power adapter
Vertical stand
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
22.3 cm
15.3 cm
3.1 cm
0.5 kg
Limited warranty - 1 year
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.79
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£20.83
£14.67
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£27.96
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£19.08
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.11
£39.19
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great product
Reviewed by Niki on 10/11/2009
Worked right out of the box. Wireless coverage is excellent and performance superb. Above all else, the wired switch performance and LAN to WAN speeds are second to none, it is amazingly fast. Setup is nice and simple, with no need to install the provided disk. It runs and looks extremely cool indeed! I particularly like the way you can set it to check for firmware updates and it will handle them all by itself with barely any need for your intervention. The interface is beautifully worked out. This is a superb "next generation" product.
5* Excellent...
Reviewed by Jason on 19/01/2010
A bit pricey when you compare it to some other routers, but the old adage you get what you pay for applies.
Dual band ABGN, all channels work flawlessly and the Wireless speed is notably higher than the old router it replaced.
Works flawlessly with the new Xbox360 Wireless N Adapter too.
5* NetGear RangeMax Dual Band Wireless-N
Reviewed by Andrew Bull on 02/12/2009
Excellent; Well designed and configurable Dual Band Router.
A worthy investment.
5* Three Years Later
Reviewed by Niki on 02/11/2012
This is still one of the best routers you can buy. I have no idea why Netgear state that this is for cable users either, since it works with any type of broadband, as long as you have a separate modem. I have used this with cable, ADSL and now use it with VDSL. It's still a fantastic router, and I have no plans to change it!
5* After Thoughts
Reviewed by Niki on 16/11/2009
Having lived with the product for a few weeks, I just wanted to add that the love affair continues! The wireless operation has been faultless, the wired is staggering. We can transfer 1GByte files from PC to PC in ten seconds!! This is true 1Gbps performance! The WAN performance is equally stunning and far exceeds the performance of the cable service we have. Wow! This is a great product.
5* Works with Virgin Media 120Mbps cable service
Reviewed by Dean on 15/09/2013
I needed a WiFi router that used Gigabit Ethernet to connect to my Virgin Media superhub to use the 120Mbps download service so I chose this NetGear router.
Wired Internet speedtest was about 90Mbps download, 10Mbps upload with the superhub set to be a modem (if you use the superhub as a router then that reduced the download to about 60Mbps)
It is no longer the fastest WiFi router on the market but it cost about £90. Previously, I had a Linksys router that died after 13 months usage and it cost about £130. So I have learnt a lesson to try not to spend over £100 on a router that could die in the near future.
The router has a web server to allow you to setup the router via a browser. I upgraded the firmware via the browser, that was straight forward as the router finds the new firmware and installs it automagically. The old firmware was out-of-date by many months.
This router has no "cloud" services which is a good thing.
WiFi seems to work adequately between floors.
Scroll to top
