BT.com
Wishlist
NetGear R6300 WiFi Router 802.11ac Dual Band Gigabit
Delivery
Standard Due date unavailable
The NETGEAR R6300 Wi-Fi Router delivers next generation WiFi at Gigabit speeds. It offers the ultimate mobility for Wi-Fi devices with speeds up to 3x faster than 802.11n. Compatible with next generation Wi-Fi devices and backward compatible with 802.11 a/b/g and N devices, it enables HD streaming throughout your home. The R6300 with simultaneous dual band Wi-Fi technology avoids interference, ensuring top Wi-Fi speeds and reliable connections. This makes it ideal for larger homes with multiple devices. In addition, four Gigabit Ethernet ports offer ultra-fast wired connections. Wirelessly access and share USB hard drive and USB printer using the two USB 2.0 ports. The NETGEAR Genie app provides easy installation from an iPad, tablet, computer or smartphone. It includes a personal dashboard, allowing you to manage, monitor, and repair your home network.
NETGEAR R6300 - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Firewall protection, auto-sensing per device, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, parental control, Quality of Service (QoS), Green Ethernet, ReadySHARE, Push ‘N’ Connect button
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
20.5 cm x 25.5 cm x 7.7 cm
654 g
Microsoft Certification
Compatible with Windows 7
United Kingdom
1 year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK
RAM
128 MB
Flash Memory
128 MB
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
External power adapter
1 x network cable
United Kingdom
Software Included
NETGEAR Genie
20.5 cm
25.5 cm
7.7 cm
654 g
Limited warranty - 1 year
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.76
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.41
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£20.60
£14.36
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£27.64
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£18.87
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£59.58
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Superb Router
Reviewed by Niki on 19/04/2013
The Netgear doesn't particularly look like an expensive piece of kit, but it's quiet sedate looks are more at home in your lounge.
I upgraded from the WNDR3700, which was a very good router. In every respect the R6300 is better. The router establishes basic settings, lets you know everything is OK, then lets you loose on the internet! You have a choice of a simple basic interface or more advanced. You may also notice how fast the interface is compared to a router that is just a few years old. Everything is built in to the router, so there is no need to install anything unless you want to. It just replaced the WNDR3700 without hassle or issue. Excellent!
Scroll to top
