BT.com
Wishlist
NETGEAR R6220 Wireless Router 4-Port Switch GigE - 802.11a/b/g/n/ac
NETGEAR R6220 Wireless Router...
£77.38
15 in stock
£77.38
Add to wishlist
Delivery
Standard 3-5 working days
Keep your many Wi-Fi devices streaming effortlessly with AC Wi-Fi technology that delivers the speed, range, and reliability you need. Avoid wireless interference with simultaneous dual bands. Play games on your tablet. Listen to tunes on your smartphone. View movies on your media player. Whatever you want to do, you're covered.
NETGEAR R6220 - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1200 Mbps
Remote Management Protocol
HTTP
Firewall protection, auto-sensing per device, NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, parental control, firmware upgradable, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), ReadySHARE, Push ā€˜Nā€™ Connect button
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
23.965 cm x 18.145 cm x 4.06 cm
385 g
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7, Windows 8
United Kingdom
1 year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1200 Mbps
HTTP
Encryption Algorithm
WPA-PSK, WPA2-PSK
880 MHz
RAM
128 MB
Flash Memory
128 MB
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
External integrated
Antenna Qty
2
External power adapter
1 x network cable
United Kingdom
23.965 cm
18.145 cm
4.06 cm
385 g
Limited warranty - 1 year
Scroll to top
