BT.com
Wishlist
NetGear ProSafe Dual Band Wireless N Access Point
Lifetime warranty
Delivery
Standard Due date unavailable
PROSAFE DUAL BAND WIRELESS-N ACCESS POINT
  • Up to 15x the speed and 10x the coverage of 802.11a, 802.11g networks
  • Stylish and elegant design with easy mounting options (e.g. ceiling, wall and desktop)
  • Concurrent operation in 2.4GHz and 5GHz radio band for maximum wireless throughput
Advanced Speed and Range with Comprehensive Internet Security
  • Backward compatibility with 802.11a, 802.11g and 802.11b network devices
  • Integrated Power over Ethernet (IEEE 802.3af PoE) lowers deployment costs
  • Centralized management via wireless controller (WC7520) for large deployments
  • Deploy wireless coverage over large areas with point-to-point and point-to-multipoint bridging via Wireless Distribution System (WDS)
  • Security feature include WPA, WPA2, rogue AP detection and 802.1x with RADIUS support
  • Easy mounting mechanism for quick wall or ceiling installation
  • Internal antennas factory-optimized for maximum RF performance
  • Antenna take-offs enable optional accessory antenna attachment for 2.4GHz operations
NETGEAR ProSafe Dual Band Wireless-N Access Point WNDAP360 - radio access point
Radio access point
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Connection / user qty: 50
UNIX, Apple MacOS, Linux, Microsoft Windows 98/ME/2000/XP/Vista
Power Over Ethernet (PoE) Supported
PoE
25.4 cm x 25.4 cm x 5.5 cm
0.88 kg
Radio access point
25.4 cm
25.4 cm
5.5 cm
0.88 kg
United Kingdom
External
Wireless
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, LAN, wireless, link/activity
Auto-sensing per device, DHCP support, power over Ethernet (PoE), VLAN support, auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, firmware upgradable, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RADIUS support, hidden SSID, wireless bridge mode, rogue access point detection
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TLS, PEAP, TTLS, WPA, WPA2
Authentication Method
Secure Shell (SSH), RADIUS, Extensible Authentication Protocol (EAP)
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
2
Gain Level
2 dBi
1 x 1000Base-T - RJ-45 , 2 x aerial , 1 x management - RJ-45
1 x network cable
Mounting Kit
Included
PoE
External power adapter
Software Included
Drivers & Utilities
Limited warranty - lifetime
Accessories
£3.69
£12.63
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£7.76
£49.24
Scroll to top
