BT.com
Wishlist
NetGear ProSafe Auxillary Power Supply 135W
Delivery
Standard Due date unavailable
The ProSAFE Auxiliary Power Supply APS135W provides a replaceable power supply for the GSM73xxSv2 series gigabit switches. You can make use of an RPS (Redundant Power Supply) while replacing the power supply. When an RPS is used, the power supply can be replaced without stopping the switch or requiring a reboot.
NETGEAR MGD SW 135W - power supply - 135 Watt
Power supply - plug-in module
Power Capacity
135 Watt
ProSAFE GSM7328S, GSM7328Sv2, GSM7352S, GSM7352Sv2
Power Capacity
135 Watt
RoHS
NETGEAR ProSAFE GSM7328S, GSM7328Sv2, GSM7352S, GSM7352Sv2
Scroll to top
