BT.com
Wishlist
NetGear ProSafe 48-port Next-Gen Edge Managed Switch
Lifetime warranty
Delivery
Standard Due date unavailable
The Next-Gen Edge M5300 series switches are NETGEAR top of the line Gigabit stackable fully managed switches for modern access layer in campus and enterprise networks with 10 Gigabit Ethernet backbone requirements. The M5300 series delivers pure line-rate performance for virtualization or convergence. NETGEAR Next-Gen Edge solutions combine latest advances in hardware and software engineering for higher availability, stronger security, better scalability, and even more energy efficiency (1.5W per port line-rate traffic for 48+4 port versions).
Netgear ProSafe Next-Gen Edge Managed Switch M5300-52G - switch - 48 ports - rack-mountable
Switch - 48 ports - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
44 x 10/100/1000 + 4 x combo SFP + 2 x combo SFP/SFP+
Performance
Bandwidth: 184 Gbps
MAC Address Table Size
32K entries
Jumbo Frame Support
12KB
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SSH, SSH-2
Flow control, Layer 2 switching, BOOTP support, ARP support, IGMP snooping, Syslog support, DiffServ support, MAC address filtering, Broadcast Storm Control, SNTP support, Weighted Random Early Detection (WRED), Spanning Tree Protocol (STP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), SSH support, DHCP server, MLD snooping, DHCP relay, Link Aggregation Control Protocol (LACP), Port Security, DHCP client, Multicast VLAN Registration (MVR), Ring Rapid Spanning Tree Protocol (RRSTP), Class of Service (CoS)
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3ak, IEEE 802.3an, IEEE 802.3aq, IEEE 802.3az
44.5 cm x 39.2 cm x 4.2 cm
6.9 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
Bandwidth: 184 Gbps
32K entries
Jumbo Frame Support
12KB
Encryption Algorithm
TLS 1.0, SSL 3.0
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
Status Indicators
Port status, power, link/activity
44 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 4 x 100Base-TX/1000Base-T - RJ-45 , 4 x SFP (mini-GBIC) , 2 x 10Gb Ethernet / 1Gb Ethernet - RJ-45 , 2 x 10Gb Ethernet / 1Gb Ethernet - SFP+ , 1 x console - mini-USB Type B , 1 x console - 9 pin D-Sub (DB-9) , 1 x USB Type A
Internal power supply
Installed Qty
1
79 Watt
Rack Mounting Kit
Included
CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, VCCI Class A ITE, EN55024, EN55022 Class A, EN50082-1, FCC Part 15 A, C-Tick Class A
44.5 cm
39.2 cm
4.2 cm
6.9 kg
50 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
Accessories
£3.74
£13.46
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.26
£52.42
Scroll to top
