BT.com
Wishlist
NETGEAR ProSafe 48-Port Gigabit L2 Managed Switch
NETGEAR ProSafe 48-Port Gigabit L2...
£508.96
Lifetime warranty
Hurry, only 2 left in stock!
£508.96
Add to wishlist
Delivery
Standard 1-3 working days
NETGEAR delivers wirespeed Gigabit performance and a full set of Layer 2 management features, as well as static routing with unsurpassed affordability. This next-generation, high-speed switch delivers maximum throughput where you need it - to high-performance workgroups at the edge of the network, or as a backbone for Fast Ethernet switches and high-speed servers in demanding small networks. The non-blocking design offers full Gigabit throughput simultaneously to all 24 or 48 10/100/1000 ports to ensure reliable performance. Flexible fiber connectivity is enabled through four combination small form-factor pluggable (SFP) gigabit interfaces. Layer 2 management functionality delivers reliability, control, and availability. Static routing enables inter-VLAN routing and provides a faster network and more effective bandwidth management. Access control lists (L2-L4) provide robust security, while L2-L4 based QoS provides enhanced traffic management capabilities. The cost-effective NETGEAR ProSafe Gigabit L2 Managed Switch creates a more productive - and future-proof - network. With increasing bandwidth requirements from applications such as voice, video, database management, and other services that slow throughput and response time, you can unleash your network and enable maximum productivity with Gigabit Ethernet for today's high-performance environments.
Multiple NETGEAR fully managed switches can be managed via a single IP address. Optimize bandwidth, security, and control with full Layer 2 management capabilities. Network administrators can use any combination of these features to ensure uptime, availability, bandwidth and throughput.
What's in the box
  • NETGEAR ProSAFE GSM7248v2
  • 4 rubber feet
  • Null modem cable
  • Rack mounting kit
NETGEAR ProSAFE GSM7248v2 - switch - 48 ports - Managed
Switch - 48 ports - Managed
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x shared SFP
Performance
Bandwidth: 96 Gbps
Virtual interfaces (VLANs): 1024 , Static routes: 32
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP
Flow control, auto-negotiation, BOOTP support, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, DiffServ support, manageable, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, DHCP snooping, Access Control List (ACL) support, Data prioritization (Qos) for VoIP applications, MLD snooping
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1v
DC 12 V
Power Redundancy
44 cm x 20.5 cm x 4.3 cm
3.7 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
Performance
Bandwidth: 96 Gbps
8K entries
Jumbo Frame Support
9KB
Routing Protocol
Static IP routing
Encryption Algorithm
TLS 1.0, SSL 3.0
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
128 MB
Flash Memory
32 MB Flash (Firmware)
Status Indicators
Port transmission speed, power, link OK, RPS (Redundant Power Supply), link/activity, fan
48 x 1000Base-T RJ-45 , 1 x serial (RS-232) management , 4 x SFP (mini-GBIC)
Internal power supply
Power Redundancy
DC 12 V
71.5 Watt
4 rubber feet
1 x null modem cable
Rack Mounting Kit
Included
MTBF
162,303 hours
FCC Class A certified, C-Tick, cUL, VCCI Class A ITE, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, FCC Part 15, UL 60950-1
Europe
Software Included
Drivers & Utilities
44 cm
20.5 cm
4.3 cm
3.7 kg
55 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
Accessories
£2.67
£3.82
£13.96
£54.43
Scroll to top
