BT.com
Wishlist
NETGEAR ProSafe 24-port Gigabit L3 Managed Stackable Switc
Lifetime warranty
Delivery
Standard Due date unavailable
NETGEAR's low-cost, stackable Gigabit Ethernet switches deliver maximum throughput and flexibility where you need it - to high-speed, high-density workgroups at the edge of the network, in the backbone of growing networks or for bandwidth-thirsty file and application servers. The ProSafe GSM7328S fully-managed switch delivers 24 ports of auto-sensing 10/100/1000 Mbps interfaces for high-density copper connectivity.
The ProSafe GSM7328S has two 10 Gigabit Ethernet small form-factor pluggable (SFP+) interfaces and two high-speed, module bays offering modular expansion for 10 Gigabit Ethernet or 48 Gigabit Stacking connectivity. The non-blocking design of the switches delivers simultaneous, full wire-speed, low-latency throughput to all ports.
A full suite of Layer 3 switching functionality ensures reliable routing between VLANs and network segmentation where and when you need it, at no additional cost. By configuring the switches into a stack of up to 8 units across a 48 Gbps bi-directional ring, a high-density, single IP-addressable switch can be built.
Robust security features include IEEE 802.1x port-based authentication and access control lists, ensuring that only authorized users can access your network. Secure management of the switches is available through Secure Sockets Layer (SSLv3) for the Web GUI and Secured Shell (SSH) for command-line sessions or with SNMP v3 for network management software. For workgroup deployments in cost-sensitive organizations that require Layer 3 switching, additional Gigabit capacity, high-value price point, flexibility of stacking, and reduced maintenance requirements, NETGEAR's ProSafe Gigabit Layer 3 Stackable switches deliver the ideal access-edge solution.
With their high-value price point, flexible design, and reduced maintenance requirements, NETGEAR's ProSafe Gigabit Layer 3 Stackable switch solutions yield a high return on investment, and are ideal for delivering highly reliable, converged voice, video, and data services over a single network infrastructure.
NETGEAR ProSAFE GSM7328Sv2 - switch - 24 ports - Managed
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x shared Gigabit SFP + 2 x SFP+
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP, DVMRP, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, OSPFv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, SSH-2
Layer 3 switching, Layer 2 switching, auto-sensing per device, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, manageable, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, sFlow, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Jumbo Frames support, DHCP server, MLD snooping, Dynamic ARP Inspection (DAI)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1v
44 cm x 39.1 cm x 4.3 cm
6.3 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
8K entries
Jumbo Frame Support
9KB
Max Units In A Stack
8
Routing Protocol
Encryption Algorithm
TLS 1.0, SSL 3.0
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
256 MB
Flash Memory
32 MB Flash
Status Indicators
Port transmission speed, power, link OK, Unit ID, status, RPS (Redundant Power Supply), link/activity, fan
24 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x RS-232 - 9 pin D-Sub (DB-9) management , 1 x USB Type A , 4 x SFP (mini-GBIC) , 2 x SFP+
Expansion Slots
2 (total) / 2 (free) x Expansion Slot
Internal power supply
76.3 Watt
Redundant Power System (RPS) connector
1 x null modem cable
Rack Mounting Kit
Included
MTBF
98,705 hours
UL, C-Tick, cUL, VCCI Class A ITE, EN55024, EN55022 Class A, CB, CCC, EN 60950-1, FCC Part 15 A
Europe
Software Included
Drivers & Utilities
44 cm
39.1 cm
4.3 cm
6.3 kg
50 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
Accessories
£3.70
£12.72
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£7.83
£49.65
Scroll to top
