BT.com
Wishlist
NetGear ProSafe 24 Port GE Stack POE Smart Switch
Delivery
Standard Due date unavailable
The ProSafe Gigabit Stackable Smart PoE (Power over Ethernet) Switches are specifically designed for growing small and mid-sized businesses (SMB) with advanced network needs for the support of multiple "the world" applications: Voice over IP (VoIP), a unified wired/wireless network, IP surveillance, converged video and data network and much more. It delivers the scalability, flexibility, reliability, and performance the SMB customers need in an affordable and easy-to-manage package.
Each ProSafe Gigabit Stackable Smart PoE Switch comes with 24 10/100/1000 Mbps ports and four shared SFP ports. All ports support standards-based PoE and as a first in the industry, they also support IEEE 802.3at-based PoE+ on the first 4 ports of each switch, capable of providing up to 30W of power to higher-powered PoE devices such as dual-band N Wireless access points, videophones and IP cameras with pan/tilt/zoom capabilities. Coupled with auto voice VLAN feature, the switch greatly reduces the complexity of VoIP deployment, and makes it easy for SMBs to implement and manage a VoIP system on their network.
The stacking feature on these switches provides the SMB with uncompromised performance, scalability and ease of network management. The only Gigabit Smart Stackable switches in the industry, they can be stacked through dedicated high-speed stacking ports (HDMI-based) with an aggregate 20 Gbps bandwidth, ensuring that the traffic between the stacked switches won't be compromised. Customers can scale up to 6 switches in one stack, and all of them can be easily configured and managed as one switch. Businesses can add switches to the stack as their network expands without making a big upfront investment at the beginning. Meanwhile, the stack's redundancy and hot-swappable capability help boost network resiliency.
These switches come with a complete suite of advanced features such as access control lists (ACL), 802.1x port authentication, enhanced QoS, rate limiting and IGMP snooping, among others, to provide SMB businesses with more robust security, higher quality of service and high availability.
An intuitive, Web browser interface provides simple yet comprehensive management, making it extremely simple to deploy and manage the advanced features, in order to realize the potential of a converged network and deliver lower total cost of ownership.
NETGEAR ProSAFE GS724TPS 24-port Gigabit Stackable PoE Smart Switch - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE) + 4 x shared SFP
Power Over Ethernet (PoE)
PoE
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP
Flow control, full duplex capability, auto-sensing per device, DHCP support, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, store and forward, MAC address filtering, Broadcast Storm Control, IP address filtering, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Access Control List (ACL) support, Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at
AC 120/230 V ( 50 - 60 Hz )
44 cm x 31 cm x 4.3 cm
4.9 kg
Europe
NETGEAR lifetime warranty
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
8K entries
Max Units In A Stack
6
Authentication Method
RADIUS, TACACS+
RAM
2 MB
Status Indicators
Link activity, port transmission speed, power, link OK
24 x 10Base-T/100Base-TX/1000Base-T - RJ-45 - PoE , Network stack device: 2 x HDMI - 19 pin HDMI Type A , 4 x SFP (mini-GBIC)
Internal power supply
235 Watt
1 x network cable
Rack Mounting Kit
Included
MTBF
116,000 hours
C-Tick, cUL, EN 60950, EN55022, VCCI Class A ITE, EN55024, CB, CCC, FCC Part 15 A
Europe
Software Included
Drivers & Utilities
44 cm
31 cm
4.3 cm
4.9 kg
50 °C
0 - 90%
Scroll to top
