BT.com
Wishlist
NetGear Powerline PLP1200 Bridge GigE HomePlug AV (HPAV) 2.0 IEEE 1901
NetGear Powerline PLP1200 Bridge...
£86.29
19 in stock
£86.29
Add to wishlist
Delivery
Standard 3-5 working days
Use your existing electrical wiring to extend your Internet access to any room in your house. Just plug the Powerline 1200 into any electrical outlet then plug in your new network connection. It's that easy. With a 1200Mbps speed, the Powerline 1200 is perfect for connecting smart TVs, streaming players, and game consoles. Plus the extra outlet provides power for additional devices.
NETGEAR Powerline PLP1200 - bridge - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV) 2.0, IEEE 1901
Data Transfer Rate
1200 Mbps
Push-and-Secure button
IEEE 802.3, HomePlug AV, HomePlug AV 2.0, IEEE 1901
5.8 cm x 4.2 cm x 12 cm
183 g
United Kingdom
1 year warranty
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
1200 Mbps
Status Indicators
Power, status
1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x IEEE 1901
Internal power supply
2 x network cable - 2 m
United Kingdom
5.8 cm
4.2 cm
12 cm
183 g
Limited warranty - 1 year
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition This item has been opened and is in excellent condition.
Ref: BSZW 034661
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£33.40
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
