BT.com
Wishlist
NETGEAR LB1111 Wireless Cellular Modem GSM, UMTS, LTE, DC-HSPA+
Delivery
Standard Due date unavailable
The NETGEAR 4G LTE Modem LB1111 is a simple LTE connectivity solution for all your devices and equipment, and the Power-over-Ethernet option is ideal for remote locations without the need to plug in a power adapter. Simply connect this LTE Modem directly to your PoE-supported equipment to provide instant 4G LTE broadband connection.
NETGEAR LB1111 - wireless cellular modem - 4G LTE
Wireless cellular modem - Gigabit Ethernet
External
Europe
Max Transfer Rate
150 Mbps
Cellular Protocol
AC 230V
Apple MacOS X 10.6.8 or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
12 cm x 9.9 cm x 3.1 cm
150 g
External
Built-in Devices
Led panel
Europe
Modem
Bus
Gigabit Ethernet
Wireless
Max Transfer Rate
150 Mbps
Cellular Protocol
Antenna
External detachable
Antenna Qty
1
Remote Management Protocol
TR-069
DMZ port, power over Ethernet (PoE), DHCP server
1 x 1000Base-T - RJ-45
SIM Card Supported
Regular (mini-SIM) x 1
1 x network cable
Power adapter
AC 230V
12 cm
9.9 cm
3.1 cm
150 g
0 - 90% (non-condensing)
Accessories
£3.79
£13.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.40
£52.66
Scroll to top
