BT.com
Wishlist
NETGEAR L2 MANAGED SWITCH 48X 10/100PT
Delivery
Standard Due date unavailable
NETGEAR has packed a lot of value into this high-density switch. Start with high port density in a one-unit box, add two gigabit uplinks to give an added edge to any growing business, then add key switch management capabilities and you have a powerful switch that costs a lot less than you'd expect.
Forty-eight 10/100 Mbps ports and two copper Gigabit Ethernet ports connect to servers or a Gigabit-speed backbone for a non-stop, always available 10/100/1000-enabled network that can quickly deliver large multimedia, image and video files. All 50-shielded RJ-45 ports automatically negotiate to the highest speed and support Auto Uplink technology to make the right link. Two hot-swappable Small Form-factor Pluggable (SFP) GBIC slots provide optional fiber connectivity for greater distance. Shipped ready to go straight out of the box, it delivers switching that's easy to set up and use.
In addition, an intuitive, Web-browser interface offers the simple Smart Switch management, making it a snap to monitor switch performance, configure ports, even set up port trunks, VLANs and traffic prioritization. Alternatively, use SNMP-based software to manage your Smart Switch.
NETGEAR ProSAFE FS750T2 48-port 10/100 Smart Switch with 2 Gigabit Ports - switch - 48 ports - Managed
Switch - 48 ports - Managed
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
48 x 10/100 + 2 x SFP + 2 x 10/100/1000
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP, HTTP
Flow control, auto-sensing per device, DHCP support, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP)
44 cm x 20.5 cm x 4.3 cm
3.2 kg
NETGEAR lifetime warranty
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
8K entries
SNMP, HTTP
RAM
128 KB
Built-in Devices
Led panel
Status Indicators
Port transmission speed, power, link/activity
48 x 100Base-TX RJ-45 , 2 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC)
Internal power supply
21 Watt
Rack Mounting Kit
Included
FCC Class A certified, C-Tick, CISPR 22 Class A, cUL, EN 60950, EN55022, IEC950, UL 1950, VCCI Class A ITE, EN55024, EN50082-1, FCC Part 15
Software Included
Drivers & Utilities
44 cm
20.5 cm
4.3 cm
3.2 kg
Accessories
£3.76
£13.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.40
£52.64
Scroll to top
