BT.com
Wishlist
NETGEAR GS105 5 Port Gigabit Switch
NETGEAR GS105 5 Port Gigabit Switch...
£24.87
Connects up to 10x faster than Fast Ethernet for maximum performance
14 in stock
£24.87
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
For a high-speed network on a small scale, nothing delivers likes these compact powerhouses. Equipped with five auto-sensing 10/100/1000 Mbps UTP ports, NETGEAR ProSafe GS105 switches give your network the capacity to handle huge workloads. If your network is configured to support jumbo frames, ProSafe GS105 switches will forward them, as well as honoring priority tags at both the layer 2 and layer 3 level. This means they move very large files across your network instantly, and keep the high priority traffic moving. Packed with ease-of-use features to simplify your networking experience, its trim design makes it an easy fit for a desk or mounted on a wall. The durable metal chassis protects interior working parts and the fanless design results in silent operation. Matched with NETGEAR's thorough testing, the ProSafe GS100 series switches provide long-lasting performance you can count on.
NETGEAR ProSAFE GS105 - switch - 5 ports - desktop
Switch - 5 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
MAC Address Table Size
4K entries
Full duplex capability, auto-sensing per device, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3p
9.4 cm x 10.4 cm x 2.8 cm
0.3 kg
United Kingdom
NETGEAR lifetime warranty
Switch - 5 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
4K entries
RAM
128 KB
Status Indicators
Link activity, collision status, port transmission speed, port duplex mode, power, link OK
5 x 1000Base-T - RJ-45
External power adapter
Mounting Kit
Included
FCC Class B certified, C-Tick, VCCI Class B ITE
United Kingdom
9.4 cm
10.4 cm
2.8 cm
0.3 kg
50 °C
10 - 90% (non-condensing)
Other bundles
£24.87
Save on TP Link Smart Plug
Save £2.00
£48.84
Accessories
£4.95
£3.85
£12.21
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.72
£55.52
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Excellent value, no problems at all.
Reviewed by Anonymous on 13/07/2007
Plugged straight in between XP Pro and Vista boxes each with Intel PRO1000/GT adapters -> copies 100Mb file in under 10secs. Runs cool & silent, uplinks to 10/100 switch via normal cable.
5* It just works
Reviewed by David on 30/11/2007
Another great easy, simple product: you just plug it in and go!
5* No Prblems
Reviewed by Ben on 10/01/2006
This is a basic product, just plug in the power and plug in your Cat 5 network cables and off you go! Works straight away with no problems. Runs completely silently (no fans) not crashed yet and been running over a month non-stop now. Can't say I have noticed any difference in performance over my 10/100 switch, but this is overkill for what I need. I have it plugged into a wireless AP and ADSL Router with no problems, I have 2 windows 2000 servers and one Windows XP all with gigabit NICs directly plugged in.
5* Nice
Reviewed by Retrodome on 23/05/2006
No problems here - just pnp
2* Limited Compatibility
Reviewed by Robert Groom on 08/04/2009
Beware that this item does not appear to be compatible with all GB Ethernet interfce cards. It would not connect at 1Gbps with my Atheros AR8121/AR8113 (built into my ASUS P5Q Pro Motherboard) or my NetGear GA311 PCI adapter using known, good cables, though neither has any problem connecting at 1Gbps to other GB rated devices. I have since read of others who have had similar issues. It appears to be some inflexibility in the way it negotiates the speed of connection. Even with both devices set manually to 1Gbps, it would still only connect at 100Mbps. Ended up reluctantly returning the item.
Scroll to top
