BT.com
Wishlist
NetGear Gigabit Ethernet 10/100/1000 Mbps 8 port Switch 300 Series
NetGear Gigabit Ethernet...
£21.86
22 in stock
£21.86
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The NETGEAR 300 Series Unmanaged Switches provide easy and affordable network connectivity to home and small offices. They are easy to use and reliable. With these Plug-N-Play switches, you can expand your network connections to multiple devices instantly. They also support the efficient use of energy, helping you save power and money.
  • Gigabit Ethernet connectivity
  • Metal enclosure
  • Energy-efficient technology for power savings
  • Auto-MDI/MDIX eliminates the need for crossover cables
  • Non-blocking switching architecture for maximum throughput at wire speed
  • Auto-negotiation for automatic connection at the highest common speed between switch and an end device
  • Fan-less design for quiet operation
NETGEAR GS308 - switch - 8 ports - unmanaged - desktop
Switch - 8 ports - unmanaged
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 16 Gbps
MAC Address Table Size
4K entries
Auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab
15.8 cm x 10.2 cm x 2.6 cm
400 g
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 16 Gbps
4K entries
Status Indicators
Power, link/activity
8 x 1000Base-T - RJ-45
External power adapter
3.8 Watt
United Kingdom
15.8 cm
10.2 cm
2.6 cm
400 g
10 - 90% (non-condensing)
Accessories
£4.95
£3.82
£11.94
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.53
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Sturdy metal cased 1 Gigabit unmanaged network switch
Reviewed by Dean on 15/09/2013
Easy to install and upgrade an older 100Mbps network to a 1Gbps network by directly replacing network switches. I plugged the network switches in and everything just worked. I purchased 3 of these network switches.
The network switch is metal cased and I personally think it is better than plastic cased products because metal is more robust. I guess the case is grey to signify 1Gpbs.
Notice that only 1 LED is present above each RJ45 network port. It seems that the link state and data flow state have been combined into a single LED (usually 2 separate LEDs would provide that information on other products). But it is OK having 1 LED; off = no connection, on = link established, blinking = data flowing (implies link established).
The mains power adapter is much smaller than older netgear mains power adapters. I guess it is a switch-mode PSU.
Scroll to top
