BT.com
Wishlist
NetGear Gigabit Ethernet 10/100/1000 Mbps 5port Switch 200 Series
NetGear Gigabit Ethernet...
£15.09
More than 50 in stock
£15.09
Add to wishlist
Delivery
Standard 3-5 working days
The NETGEAR 200 series unmanaged switch provides easy and affordable network connectivity to home and small offices. It is easy to use and reliable. With these Plug-and-Play switch, you can expand your network connections to multiple devices instantly. The 200 series also supports the efficient use of energy, helping you save power and money.
NETGEAR GS205 - switch - 5 ports - unmanaged - desktop
Switch - 5 ports - unmanaged
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Bandwidth: 10 Gbps
MAC Address Table Size
4K entries
Auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab
11.4 cm x 8.6 cm x 2.6 cm
122 g
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Bandwidth: 10 Gbps
4K entries
Status Indicators
Power, link/activity
5 x 1000Base-T - RJ-45
External power adapter
3.56 Watt
United Kingdom
11.4 cm
8.6 cm
2.6 cm
122 g
10 - 90% (non-condensing)
Accessories
£5.11
£3.88
£12.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.92
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£56.55
Scroll to top
