BT.com
Wishlist
NetGear Dual Band Universal WiFi Extender
Delivery
Standard Due date unavailable
The NETGEAR Universal Dual Band Wi-Fi Range Extender - Wall-plug Edition, simultaneously extends Wi-Fi coverage of an existing Wi-Fi network throughout your home so you can get better coverage for your Wi-Fi devices - on your patio or even in the backyard. The Wi-Fi Extender supports simultaneous dual band Wi-Fi coverage so you can connect devices on both 2.4 GHz and 5 GHz bands. While providing better Wi-Fi coverage, the Wi-Fi Extender also allows you to play music wirelessly over your network through any stereo or speaker in your home. By plugging in a USB printer into the USB port on the Wi-Fi Extender, you can make any wired USB printer accessible wirelessly from any Wi-Fi device and any room in your home.
NETGEAR WN3500RP - Wi-Fi range extender
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Docking station
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7
12 cm x 7.9 cm x 4.2 cm
238 g
12 cm
7.9 cm
4.2 cm
238 g
United Kingdom
External
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, status, WPS
Auto-sensing per device, print server, Wi-Fi Protected Setup (WPS), Push ‘N’ Connect button, FastLane Technology
Encryption Algorithm
WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED
1 x 100Base-TX - RJ-45 , 1 x USB 2.0 - Type A , 1 x audio
Docking station
RoHS, WEEE, CEC
Internal power supply
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.72
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.26
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£21.20
£14.65
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.90
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£18.55
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
1* A terrible experience connecting this and had to return it; also terrible experience trying to retur
Reviewed by Lucy on 26/08/2015
1 hour trying to install it on my own; 1 and a half hours on the phone with Netgear; then it was declared faulty. Now finding it difficult to return it. Am 3 hours behind with my work which I'll have to make up tonight in unpaid overtime. Nightmare! Take care when buying this product!
Scroll to top
