BT.com
Wishlist
NETGEAR 8-Port 10/100/1000 Mbps Switch
NETGEAR 8-Port 10/100/1000 Mbps...
£33.86
17 in stock
£33.86
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Now you can have a powerful, high-speed network on a small scale. NETGEAR's GS108 Gigabit Ethernet Switch lets you build a system that provides a full, dedicated 1000, 100, or 10 Mbps connection so you can move very large files across your network instantly. The GS108 also lets you painlessly integrate 10, 100, and 1000 Mbps devices. This potent switch is packed with ease-of-use features to simplify your workday experience. Its compact design fits neatly into small workspaces and, since it's self-cooling without a fan, it runs silently and unobtrusively.
NETGEAR's GS108 Gigabit Ethernet Switch moves huge files fast! It features a high-speed, auto-switching 10/100/1000 Mbps Ethernet connection. And because Copper Gigabit Ethernet is a full duplex standard, you can get up to 2000 Mbps on each port.
NETGEAR's GS108 Gigabit Ethernet Switch integrates 10, 100, and 1000 Mbps devices on the same network. Every port automatically senses the right speed and full/half duplex mode, while Auto Uplink technology automatically adjusts for straight-through or crossover cables.
LEDs embedded in each of the 8 RJ-45 jacks make for easy monitoring. Space-saving dimensions are ideal for desktop or wall mounting in home and small office environments. And it runs quietly, self-cooling without an internal fan.
NETGEAR ProSafe GS108 8-port Gigabit Desktop Switch 10/100/1000 Mbps - switch - 8 ports - desktop
Switch - 8 ports
Enclosure Type
Desktop
Ports
8 x 10/100/1000
MAC Address Table Size
8K entries
Full duplex capability, auto-sensing per device, auto-uplink (auto MDI/MDI-X)
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab
28.7 cm x 10 cm x 2.5 cm
0.9 kg
Apple MacOS, Novell NetWare, Microsoft Windows
NETGEAR lifetime warranty
Switch - 8 ports
Enclosure Type
Desktop
Ports
8 x 10/100/1000
8K entries
Status Indicators
Port status, collision status, port transmission speed, power
8 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Power adapter - external
17.5 Watt
15.5cm
10cm
2.6cm
0.9 kg
Mounting Kit
Included
FCC Class A certified, C-Tick, cUL, EN55022, UL 1950, VCCI Class A ITE
10 - 90%
Other bundles
£33.86
Save on TP Link Smart Plug
Save £2.00
£57.83
Accessories
£4.95
£3.85
£12.21
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.72
£55.52
Customer reviews
Write review Read all The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Faultless for exactly 15 months, then died
Reviewed by J Young on 16/07/2008
Yes - mine died too - just engaging the support to see if I can get a replacement. Power supply seems to be overcooking it a bit (16v instead of 12v)
5* And then we all fell down...
Reviewed by Kris on 24/07/2008
BT delivered as usual - however now my little GS108UK has taken to flashing every single port (both LEDs) if I have ANYTHING hooked in that it doesn't like or is set to auto-negotiate up to Gigabit. I fear it may be on it's last legs but I'm fortunate that I bought it over 2 years ago (or so it seems).
5* Still going strong
Reviewed by John Brett on 11/10/2010
Mine's been running perfectly for 18 months, now. I plugged it in and it has done everything I've asked of it over that time without the slightest problem.
5* Excellent Value For Money
Reviewed by D Macklam on 11/10/2007
This is a quality piece of kit, fast transfer rates, solidly built, Netgear reliability and build quality. I've just put this in a small office network with 4 Belkin gigabit PCI cards and all is working perfectly. Would recommend. The cheaper Netgear may be good enough for home use but for office buy this one, it's bomb proof!
5* Oh well...
Reviewed by Brian J on 15/05/2008
Faultless for 15 months then died.
The end.
5* Also faultless for about 15 months...
Reviewed by Adrian J on 10/06/2008
...and also died.
There seems to be a common problem with these, which manifests itself as the "little blinking lights of death".
But it's from the ProSafe range, and has a lifetime warranty. The returns procedure is a little bizare (you're emailed a phone number which you have to call, in order to be given another email address to get a returns number and another phone number to arrange collection from the courier!) but a replacement turned up within a week.
5* Excellent
Reviewed by Sina Mohajer on 15/02/2006
This switch is very stable. Doesn't get very hot and I can tell its a durable piece of equipment.
I have mixed both CAT6, and CAT5 cables, connected my wireless router to it, and everything is running perfectly.
The switch automatically detects whether a connection is 100mb or 1000 mb. There is no fan, dead silent.
Data Transfer rates are fast, and I have had no problem what so ever. I recommend this to anyone who is serious about networking.
5* Recommended: NetGear 8-Port 10/100/1000 Mbps Switch
Reviewed by Anonymous on 06/06/2006
The GS108 is a very robust, reliable unit that is incredibly easy to setup and use. Compatibility with the whole range of speeds, 10/100/1000Mb/s has been no trouble whatsoever in my experience. I have been using my GS108 for nearly a year now, and it has been great- runs silent and cool. If you want an 8 port gigabit switch, you will not be disappointed with this choice.
My only criticism of the unit is the way the status LEDs operate. Activity is indicated by flashing status lights. These flash on and of regularly at approximately 0.5 second intervals when the port is active irrespective of the volume of traffic. So if you ping one device and transfer a large file from another device, the GS108 activity status LEDs flash indistinguishably for the two different functions. Trivial I know, but unfortunate nonetheless.
5* Better than avarage
Reviewed by Chris Frenzel on 08/11/2006
It may be a bit more expensive then the very cheap offerings, but you do get a much better switch for your money – after installing this switch between my servers there was a noticeable improvement over the cheaper belkin switch, this mostly was due to jumbo frame support and better 10/100/1000 switching. If you are a home user then the GS608UK will probably do just as well and costs less,
4* Great while they last
Reviewed by Anonymous on 08/06/2008
Perfect, plug stuff in and it works as you'd expect. Sadly it seems they aren't designed to last (do a search) - Had mine 15 months and now it's only good as an Xmas decoration with flashing lights regardless of whats connected. Others report it's down to bad capacitors and if your good with an iron can repair it. I wouldn't recommend it unless you only want them just long enough for the warrently to expire :( Shame.
Scroll to top
