BT.com
Wishlist
NETGEAR 48P Gige Unmanaged Rackmount Swch
NETGEAR 48P Gige Unmanaged...
£212.98
27 in stock
£212.98
Add to wishlist
Delivery
Standard 1-3 working days
Marketing description is not available.
NETGEAR GS348 - switch - 48 ports - unmanaged - rack-mountable
Switch - 48 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000
Performance
Bandwidth: 96 Gbps , Forwarding rate: 1448000 packets per second , Latency (64-byte packets): <4 µs
MAC Address Table Size
16K entries
Jumbo Frame Support
9216 bytes
Flow control, auto-sensing per device, Quality of Service (QoS), Energy Efficient Ethernet, DiffServ Code Point (DSCP) support, 1.5MB packet buffer, cable test
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
AC 120/230 V (50 - 60 Hz) 1 A
44 cm x 20.4 cm x 4.32 cm
3.15 kg
Europe
3 years warranty
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000
Performance
16K entries
Jumbo Frame Support
9216 bytes
Status Indicators
Power, link/activity
48 x 1000Base-T RJ-45
Internal power supply
Electric Current Required
1 A
23 Watt
Rubber feet
Rack Mounting Kit
Included
Plug and Play
Europe
44 cm
20.4 cm
4.32 cm
3.15 kg
Limited warranty - 3 years
50 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95%
Scroll to top
