BT.com
Wishlist
NetGear 12-Port Gigabit PoE Desk Layer 2 Managed Switch
Delivery
Standard Due date unavailable
The NETGEAR ProSafe "Intelligent Edge" Gigabit L2+ managed switch GSM5212P consist of 12-port Gigabit with PoE+ connectivity, and 4-port dual-speed SFP with fiber connectivity. Intelligent Edge series deliver a secure and flexible access in campus, commercial and enterprise converged environments: Wireless access points, IP telephony and video-surveillance.
NETGEAR ProSAFE GSM5212P - switch - 12 ports - Managed - rack-mountable
Switch - 12 ports - L2+ - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
12 x 10/100/1000 (PoE+) + 4 x shared SFP
Power Over Ethernet (PoE)
PoE+
Performance
Switching capacity: 24 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
VLAN support, DiffServ support, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), Jumbo Frames support, DHCP server, PoE+, IPv4 support, Link Aggregation Control Protocol (LACP), DHCP client
IEEE 802.3af, IEEE 802.1x, IEEE 801.1p
33.1 cm x 20.8 cm x 4.4 cm
2.596 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
Performance
8K entries
Jumbo Frame Support
Max Units In A Stack
8
Routing Protocol
Static IP routing
Authentication Method
RADIUS, TACACS+
12 x 10Base-T/100Base-TX/1000Base-T - RJ-45 PoE+ , 1 x RS-232 - 9 pin D-Sub (DB-9) management , 1 x USB , 4 x SFP (mini-GBIC)
Internal power supply
38.5 Watt
MTBF
239,032 hours
33.1 cm
20.8 cm
4.4 cm
2.596 kg
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.72
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.41
£15.31
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£23.18
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£20.07
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£45.37
£28.05
£50.76
Scroll to top
