Click to visit BT.com
BT.com
Wishlist
NetGear N750 Wireless Dual Band Gigabit Router
NetGear
Quicklinx: 8V7SWS00
Mfr#: WNDR4300-100UKS
The NETGEAR N750 Wireless Dual Band Gigabit Router--Premium Edition offers high-performance wireless speeds up to 300+450 Mbps and with simultaneous dual band technology avoids interference, ensuring top WiFi speeds and reliable connections. It supports a wide range of new features and applications such as ReadySHARE® Cloud**, ReadySHARE® Printer, and is Time Machine® compatible to create a powerful home network for applications such as streaming HD video and multi-player gaming. Improved wireless range delivers better connections for medium to large homes and multiple devices, while four Gigabit Ethernet ports offer ultra-fast wired connections. USB port enables faster USB access speeds for wireless connections to external hard drives and printers.
SPEED - FASTER WIFI SPEED 300+450
GIGABIT WIRED--Ideal for HD gaming & video
WIFI RANGE - ULTIMATE RANGE, Improved for larger homes
SHARING - DLNA®--Find & play your media on DLNA TVs & game consoles
ReadySHARE USB ACCESS--Wirelessly access & share USB hard drives
ReadySHARE Printer - Wirelessly access & share share a USB printer
Time Machine - TIME MACHINE® COMPATIBLE--Automatic Mac backup to connected USB hard drive, wirelessly
ReadySHARE Cloud - READYSHARE® CLOUD**--Access & share files on a USB hard drive remotely
RELIABLE CONNECTIONS SIMULTANEOUS DUAL BAND - SIMULTANEOUS DUAL BAND--Reduces WiFi interference & doubles bandwidth
ADVANCED QoS--Optimized for smooth HD streaming & gaming
EASE OF USE - CD-LESS Setup
EASY INSTALL--Easy setup for iPad®, tablets, smartphones & computers
NETGEAR GENIENETGEAR GENIE® APP--Home network manager
PUSH 'N' CONNECT--Easy push button WiFi connections (WPS)
WIFI & POWER ON/OFF--Convenient power savings
SECURITY- PARENTAL CONTROLS--Web filtering for all your connected devices
GUEST NETWORK ACCESS--Separate & secure access for guests
PUSH 'N' CONNECT SECURE WIFI CONNECTIONS--Highest level wireless security with WPA/WPA2
NETGEAR WNDR4300 - Premium Edition - wireless router - 802.11a/b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Data Transfer Rate
750 Mbps
Auto-sensing per device, NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), ReadySHARE, Live Parental Controls, Push ‘N’ Connect button
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, DLNA CERTIFIED
21.8 cm x 16 cm x 3.5 cm
450 g
Microsoft Certification
Compatible with Windows 7
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7
United Kingdom
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz, 5 GHz
Data Transfer Rate
750 Mbps
Encryption Algorithm
WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, DLNA CERTIFIED , RoHS, WEEE, CEC
RAM
128 MB
Flash Memory
128 MB
LAN : 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN : 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0 : 1 x 4 pin USB Type A
Aerial
Aerial
Internal
External power adapter
Vertical stand
1 x network cable
United Kingdom
Software Included
NETGEAR Genie
21.8 cm
16 cm
3.5 cm
450 g
