BT.com
Wishlist
NEC X651UHD 65" 3840x2160 DVI-D HDMI LCD Display
Delivery
Standard Due date unavailable
This display sets amazing standards in image size and quality with an 65" canvas with UHD (3840x2160) resolution. State of the art innovation delivers 24/7 runtimes with high end components and LED backlighting. It is ideal for any industrial application, from control rooms to conferencing to life size digital signage.
NEC MultiSync X651UHD X Series - 65" LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i
Video Interface
HDMI
HDMI Ports Qty
4 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-IPS
LCD Backlight Technology
LED backlight - edge-lit
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
AC 120/230 V
Energy Class
Class A+
200 Watt
Power Consumption (On mode)
100 W
Energy Consumption per Year
146 kWh
147.2 cm x 8.4 cm x 84.7 cm
3 years warranty
Energy Class
Class A+
200 Watt
100 W
146 kWh
Diagonal Class
65"
Commercial Use
Series
X Series
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS), temperature sensor, NFC sensor
Video Interface
HDMI
HDMI Ports Qty
4 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode, Eco mode
Dimensions
Without stand
147.2 cm
8.4 cm
84.7 cm
Display
LCD Display Technology
S-IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Contrast Ratio
1400:1
Brightness
450 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
12 ms
Colour Temperature Control
Open Pluggable Specification slot, Carbon Footprint Meter
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
2 x network , Serial input , DisplayPort input , 2 x DVI-D input , 4 x HDMI input , 2 x audio input , Remote control input
NaViSet Administrator 2
DisplayPort cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, PSB, RoHS
Power supply
Nominal Voltage
AC 120/230 V
Power Consumption Stand by
2.5 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
Scroll to top
