BT.com
Wishlist
NEC X555UNS 55" 1920 x 1080 LED Large Format Display
NEC X555UNS 55" 1920 x 1080 LED...
£4,917.18
£4,917.18
Add to wishlist
Delivery
Standard 1-3 working days
The ultra slim X555UNS features a 3,5 mm bezel to create impressive high resolution videowalls with barely visible bezels. Connectivity and Sensors allow additional creativity in the content displayed. The unique built-in NFC sensor in combination with NEC's Android app reduces installation and maintenance times, especially useful on larger installations.
The perfect picture quality and high product reliability make the X555UNS an ideal solution for retail signage, control room applications, transport installations and the rental market.
NEC MultiSync X555UNS X Series - 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
WLED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Remote Control
Standard remote
Energy Class
Class C
310 Watt
Energy Consumption per Year
225 kWh
121.3 cm x 9.5 cm x 68.4 cm
30.3 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Energy Class
Class C
310 Watt
225 kWh
Diagonal Class
55"
Series
X Series
TV Tuner
No tuner
Sensors
Temperature sensor, NFC sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
Dimensions
Without stand
121.3 cm
9.5 cm
68.4 cm
30.3 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Image Contrast Ratio
1200:1
Brightness
700 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
12 ms
TileMatrix, Open Pluggable Specification slot, Carbon Footprint Meter, auto tiling function, automatic alarm e-mails, Frame Comp, HTTP server, Point Zoom function
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Remote Control
Standard remote
Audio System
External Speakers Amplifier Power (Total)
30 Watt
Connector Type
2 x network ¦ USB ¦ Serial input ¦ DisplayPort input ¦ DisplayPort output ¦ DVI-D input ¦ VGA input ¦ HDMI input ¦ 2 x audio input ¦ Audio output ¦ Speakers output ¦ Remote control input
DisplayPort cable ¦ Network cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, VESA FDMI, PSB, RoHS
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Power Consumption Stand by
0.5 Watt
On / Off Switch
Limited warranty - 3 years ¦ Limited warranty - backlight - 3 years
20 - 80%
Scroll to top
