BT.com
Wishlist
NEC X554UNS 55" 1920x1080 DVI-D HDMI LED Display
NEC X554UNS 55" 1920x1080 DVI-D...
£4,228.23
£4,228.23
Add to wishlist
Delivery
Standard 1-3 working days
Transform your video walls with the immaculate high definition of the 55" X554UNS. Direct LED backlighting reduces power consumption and improves edge-to-edge brightness uniformity. Mere millimeters separate content from display to display which ensures a smooth transition across a video wall. This display is ideal for digital signage, boardrooms, entrance lobbies and broadcast applications, and can be deployed in video wall applications up to 10 x 10 in size utilizing integrated TileMatrix technology.
NEC MultiSync X554UNS X Series - 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-PVA
LCD Backlight Technology
WLED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Remote Control
Standard remote
Energy Class
Class C
300 Watt
Power Consumption (On mode)
156 W
Energy Consumption per Year
228 kWh
121.35 cm x 10.04 cm x 68.43 cm
27.9 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Energy Class
Class C
300 Watt
156 W
228 kWh
Diagonal Class
55"
Series
X Series
TV Tuner
No tuner
Sensors
Temperature sensor, NFC sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
Dimensions
Without stand
121.35 cm
10.04 cm
68.43 cm
27.9 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Image Contrast Ratio
3500:1
Brightness
700 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
8 ms
TileMatrix, Open Pluggable Specification slot, Carbon Footprint Meter, auto tiling function, automatic alarm e-mails, Frame Comp, HTTP server, Point Zoom function
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Remote Control
Standard remote
Audio System
External Speakers Amplifier Power (Total)
30 Watt
Connector Type
2 x network , USB , Serial input , DisplayPort input , DisplayPort output , DVI-D input , VGA input , HDMI input , 2 x audio input , Audio output , 2 x speakers output , Remote control input
NaViSet Administrator 2
DisplayPort cable , Network cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, PSB, RoHS
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Power Consumption Stand by
0.5 Watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
20 - 80%
Scroll to top
