BT.com
Wishlist
NEC X474HB 47" DVI HDMI DisplayPort LCD Display
NEC X474HB 47" DVI HDMI DisplayPort...
£3,688.94
£3,688.94
Add to wishlist
Delivery
Standard Due date unavailable
The 47-inch specialty LCD display is designed to intelligently adapt to its surroundings, offering a bright, clear image when required, without wasting energy when it's not. Offering a brightness of up to 2000 cd/m2 - nearly three times that of most other professional large-screen displays - the X474HB is easily visible in shopping windows or cabinets for outdoor applications.
NEC's X474HB display is designed to cope with the durability and readability challenges that often arise in sunlit areas. As such, this display is ideal for any heavy duty digital signage application that requires enhanced visual performance, flexible control and connectivity as well as long operating hours.
NEC MultiSync X474HB X Series - 47" LED display
LED-backlit LCD flat panel display
Diagonal Class
47"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-IPS
LCD Backlight Technology
LED backlight - local dimming, direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Energy Class
Class D
370 Watt
Power Consumption (On mode)
190 W
Energy Consumption per Year
277 kWh
108.4 cm x 14.7 cm x 62.8 cm
26.9 kg
3 years warranty
Energy Class
Class D
370 Watt
190 W
277 kWh
Diagonal Class
47"
Series
X Series
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode, Eco mode
Dimensions
Without stand
108.4 cm
14.7 cm
62.8 cm
26.9 kg
Display
LCD Display Technology
S-IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
1300:1
Brightness
2000 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
10 ms
Auto tiling function, automatic alarm e-mails, HTTP server, Point Zoom function
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
300 x 300 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
HDMI , USB , Serial input , 2 x audio input , VGA input , DisplayPort input , DVI-D input , Remote control input , 2 x network , Audio output , Speakers output , DisplayPort output
NaViSet Administrator 2
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, PSB, RoHS
Power supply
Power Consumption Stand by
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
Scroll to top
