BT.com
Wishlist
NEC X464U64UNV 46" 1920x1080 HDMI DVI-D DisplayPort LCD Display
NEC X464U64UNV 46" 1920x1080 HDMI...
£2,446.56
Hurry, only 2 left in stock!
£2,446.56
Add to wishlist
Delivery
Standard 1-3 working days
The ultra slim X464UNV features a very thin bezel to create impressive high resolution videowalls with barely visible bezels. Connectivity and sensors allow additional creativity in the content displayed. The unique built-in NFC sensor in combination with NEC's Android app reduces installation and maintenance times, especially useful on larger installations. The perfect picture quality and high product reliability make the X464UNV an ideal solution for retail signage, control room applications, transport installations and the rental market.
NEC MultiSync X464UNV-2 X Series - 46" LED display
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Motion Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-PVA
LCD Backlight Technology
WLED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
Speakers not included
Voltage
Energy Class
Class A
115 Watt
Power Consumption (On mode)
66 W
Energy Consumption per Year
96 kWh
102.4 cm x 11.73 cm x 57.86 cm
24.3 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Energy Class
Class A
115 Watt
66 W
96 kWh
Diagonal Class
46"
Commercial Use
Series
X Series
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS), NFC sensor
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
Dimensions
Without stand
102.4 cm
11.73 cm
57.86 cm
24.3 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Image Contrast Ratio
3500:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
TileMatrix, Open Pluggable Specification slot, auto tiling function, automatic alarm e-mails, Frame Comp, HTTP server
Stands & Mounts
Flat Panel Mount Interface
300 x 300 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Audio System
Speaker System
External Speakers Amplifier Power (Total)
30 Watt
Connector Type
DVI-D input , HDMI , DisplayPort input , DisplayPort output , VGA input , Remote control input , Serial input , 2 x audio input , 2 x network , USB , Audio output , Speakers output
DisplayPort cable , Network cable
VESA DPMS
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
1 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
Scroll to top
