BT.com
Wishlist
NEC X462S 46" 1920x1080 DBI HDMI LED Backlight Display
NEC X462S 46" 1920x1080 DBI HDMI...
£1,620.70
£1,620.70
Add to wishlist
Delivery
Standard 1-3 working days
The LED-backlit 46" NEC X462S offers customers a super-slim depth of 1.7" and a brighter screen than its predecessor. This industrial-strength, Full HD LCD display delivers high-quality imagery with advanced connectivity, including DisplayPort, HDMI and an Open Pluggable Specification (OPS) slot. These digital options increase flexibility for users in a variety of digital signage applications, especially video walls where up to 100 displays can be used in a 10 x 10 configuration. The optional color calibration solution enables color uniformity and fidelity across individual and multiple screens, creating a perfectly matched image in tiled digital signage environments. The X462S is ideal for hospitality, retail and government applications where minimal depth is required.
NEC MultiSync X462S X Series - 46" LED display
LED-backlit LCD flat panel display
Diagonal Class
46"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
Video Wall Components Qty
100
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-PVA
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Microsoft Certification
Compatible with Windows 7
Voltage
Energy Class
Class C
255 Watt
Power Consumption (On mode)
116 W
Energy Consumption per Year
170 kWh
105.93 cm x 4.61 cm x 61.3 cm
20.7 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Energy Class
Class C
255 Watt
116 W
170 kWh
Diagonal Class
46"
Series
X Series
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode, Eco mode
100
Cooling System
Fanless
Dimensions
Without stand
105.93 cm
4.61 cm
61.3 cm
20.7 kg
Enclosure Colour
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
4000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Scheduler Function (with RTC), TileMatrix (10 x 10), Open Pluggable Specification slot, Carbon Footprint Meter
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
300 x 300 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 960, 1280 x 720, 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1280 x 800, 1400 x 1050, 720 x 576
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
10 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x speaker - built-in - 5 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connector Type
DisplayPort input , HDMI input , DVI-D input , DVI-D output , VGA input , Composite video input , Network , Remote control input , Remote control output , Audio input , Audio output , 2 x speakers output
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2Bi, VESA DPMS, VESA FDMI, PSB, RoHS
ENERGY STAR Certified
ENERGY STAR Version
5.1
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
Scroll to top
