BT.com
Wishlist
NEC V423TM 42" LCD Large Format Display
Delivery
Standard Due date unavailable
NEC's 42" V423-TM touch integrated large-screen LCD display offers digital signage users touchscreen capabilities at a cost-conscious price. This display also utilizes LED-backlighting to minimize depth and power consumption. Within the V423-TM bezel is an integrated, low-profile, 4-camera optical-imaging technology that allows for up to six simultaneous touches. Its anti-reflective glass coating protects the panel and allows for higher brightness transmittance. The touchscreen, high-performance panel and abundant advanced technologies promote extended use, making the V423-TM ideal for corporate, retail, restaurant and way finding kiosks.
NEC MultiSync V423-TM V Series - 42" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
42"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
Video Wall Components Qty
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-IPS
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
DICOM Simulated Gamma
Speaker System
2 speakers
Remote Control
Standard remote
Microsoft Certification
Compatible with Windows 7
Voltage
Energy Class
Class B
360 Watt
Power Consumption (On mode)
85 W
Energy Consumption per Year
124 kWh
100.8 cm x 8.33 cm x 60.1 cm
24.4 kg
3 years warranty
Energy Class
Class B
360 Watt
85 W
124 kWh
Diagonal Class
42"
Combined with
Touchscreen
Series
V Series
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode, Eco mode
Protection
Protection glass
100
Cooling System
Fanless
Dimensions
Without stand
100.8 cm
8.33 cm
60.1 cm
24.4 kg
Enclosure Colour
Display
LCD Display Technology
S-IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Coating
Anti-reflection
Image Contrast Ratio
1300:1
Brightness
430 cd/m²
Viewing Angle
87 degrees
Viewing Angle (Vertical)
87 degrees
Touchpoints Qty
5
Response Time
12 ms
TileMatrix (10 x 10), Multitouch, Aspect ratio control (ARC), Optical Touch technology, Open Pluggable Specification slot
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
300 x 300 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 960, 1280 x 720, 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1280 x 800, 1400 x 1050, 720 x 576
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DisplayPort input , HDMI input , DVI-D input , DVI-D output , Component video / composite video / VGA input , Composite video input , Network , Serial input , Serial output , Remote control input , 2 x speakers output , Audio input , Audio output
VGA cable , USB cable , DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, PSB, RoHS
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
35 °C
20 - 80%
Scroll to top
