BT.com
Wishlist
NEC V323-2 32" Public Display 1920x1080  450cd/m2  1300
NEC V323-2 32" Public Display...
£720.00
11 in stock
£720.00
Add to wishlist
Delivery
Standard 1-3 working days
NEC's 32" V323-2 high-performance large-screen display utilizes LED backlighting to deliver both environmental and functional benefits for digital signage. The V323-2's commercial-grade panel is capable of displaying brilliant imagery and capturing the audience's attention. This full HD model features a mechanical design as well as an Open Pluggable Specification (OPS)-compliant expansion slot, which future-proofs the display and allows for the seamless integration of a computer or other NEC/third-party component. Because video, RS-232 control and power are passed internally from the display to the computer, additional cabling is not required, thereby simplifying installations. With integrated temperature sensors and fans, this display is ideal in applications that require extended use, including retail stores, restaurants, indoor venues, training facilities and airports.
NEC MultiSync V323-2 V Series - 32" Class (31.5" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
32"
Diagonal Size
31.5 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
Motion Enhancement Technology
60 Hz Refresh Rate
Video Wall Components Qty
100
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-IPS
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Microsoft Certification
Compatible with Windows 7
Voltage
155 Watt
75 cm x 6 cm x 44.4 cm
3 years warranty
155 Watt
Diagonal Class
32"
Diagonal Size
31.5 in
Commercial Use
Series
V Series
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
100
Cooling System
Fanless
Dimensions
Without stand
75 cm
6 cm
44.4 cm
Enclosure Colour
Display
LCD Display Technology
S-IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Image Contrast Ratio
1300:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
NaViSet, Scheduler Function (with RTC), TileMatrix (10 x 10), Open Pluggable Specification slot
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1360 x 768, 640 x 400, 1920 x 1080
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x main channel speaker - built-in - 8 Watt
Connector Type
DVI-D output , VGA input , DVI-D input , HDMI input , DisplayPort input , Audio input , Network , Remote control input , Serial input , Audio output , Serial output
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, BSMI, cUL, DDC-2Bi, SASO, TUV S, VESA DPMS, VESA FDMI, PSB, KCC, KC, EAC
Power supply
Nominal Voltage
Power Consumption Stand by
1 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
Scroll to top
