BT.com
Wishlist
NEC V260 3D Ready DLP SVGA Projector - 2600 ANSI Lumens
Delivery
Standard Due date unavailable
NEC values the relationships that the company has with all of its customers - individuals and corporate customers alike. NEC constantly strives to provide the level of service and support that is expected of an industry leader.
NEC V260 - DLP projector - 3D
DLP projector
3D Capable
Built-in Devices
Speaker
Brightness
2600 lumens
Contrast Ratio
2000:1
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Bulb type
180 Watt
Bulb life cycle
Up to 3000 hour(s) / up to 5000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Speakers
Speaker(s) - internal
AC 120/230 V (50 - 60 Hz)
233 Watt
31 cm x 9.5 cm x 24.7 cm
2.5 kg
3 years warranty
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Brightness
2600 lumens
Contrast Ratio
2000:1
Image Size
76 cm - 762 cm
Projection Distance
1.2 m - 13 m
Throw Ratio
1.95 - 2.15:1
Resolution
SVGA - SVGA (800 x 600) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
180 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction, aspect control
Eco-Mode technology, 6-segment colour wheel, BrilliantColor, DLP 3D Ready, VIDI Lighting Technology
Lens
Focus Type
Manual
Zoom Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
7 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x remote control - 9 pin D-Sub (DB-9) , 1 x S-video input - 4 pin mini-DIN
Lens cover, wireless remote control
1 x VGA cable - 1.8 m
Security Features
TUV GS, RoHS, ErP Ready
Nominal Voltage
233 Watt
Power Consumption Operational (Standby)
0.5 Watt
31 cm
9.5 cm
24.7 cm
2.5 kg
Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
Sound Emission
34 dB
31 dB
Scroll to top
