Click to visit BT.com
BT.com
Wishlist
NEC V230X DLP 3D Ready XGA Projector - 2300 ANSI Lumens
Quicklinx: 7HWGWS00
Mfr#: 60003177
Get the ultimate 3D experience with a 3D ready DLP projector from NEC. DLP-Link technology allows 3D images to be projected with the aid of a single projector and active glasses without special screens, filters or emitters. The impression of 3D is created by the interaction with the active LCD shutter glasses. The easy to set up alternative to traditional 3D stereo projection! It's an ideal solution for classrooms, (small) meeting rooms, cross-use (private/professional), mobile/cooperative applications.
NEC V230X DLP projector - 3D
DLP projector
3D Capable
Built-in Devices
Speaker
Brightness
2300 lumens
Contrast Ratio
2000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
180 Watt
Bulb life cycle
Up to 3500 hour(s) / up to 5000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video ( NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60 )
Speakers
Speaker(s) - internal
AC 120/230 V ( 50/60 Hz )
233 Watt
31 cm x 9.5 cm x 24.7 cm
2.5 kg
3 years warranty
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Brightness
2300 lumens
Contrast Ratio
2000:1
Image Size
76 cm - 762 cm
Projection Distance
1.2 m - 13 m
Throw Ratio
1.95 - 2.15:1
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
180 Watt
Bulb life cycle
Eco-Mode technology, 6-segment colour wheel, wall colour correction, BrilliantColor, DLP 3D Ready, VIDI Lighting Technology
Lens
Focus Type
Manual
Zoom Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
7 Watt
Speakers
1 x mixed channel
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x audio line-in - mini-phone 3.5mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone 3.5mm , 1 x remote control - 9 pin D-Sub (DB-9) , 1 x S-video input - 4 PIN mini-DIN
Lens cover, wireless remote control
1 x VGA cable - 1.8 m
Security Features
TUV GS, RoHS, ErP Ready
Nominal Voltage
233 Watt
Power Consumption Operational ( Standby )
0.5 Watt
31 cm
9.5 cm
24.7 cm
2.5 kg
3 years warranty
Service & Support Details
Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
Sound Emission
34 dB
31 dB
