Click to visit BT.com
BT.com
Wishlist
NEC U310W Ultra Short Throw 3D Ready DLP Projector - 3100 ANSI Lumens
Quicklinx: 7HX3WS00
Mfr#: 60003137
Enjoy large images even in meeting rooms with small space. Less shadow and glare gives the presenter more space to engage with his audience and enhances the experience with interactive white boards. Go wide with your presentations and play video content in native aspect ratio. Free installation angles give you additional freedom for eye catching digital signage installations. DLP technology ensures that there is no color decay during long daily operating hours. It is an ideal solution for meeting rooms and digital signage applications, as well as for classrooms.
NEC U310W DLP projector - 3D
DLP projector - High Definition 720p
3D Capable
Built-in Devices
Speaker
Brightness
3100 lumens
Contrast Ratio
1800:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
280 Watt
Bulb life cycle
Up to 2500 hour(s) / up to 3000 hour(s) (economic mode)
Video Input
RGB, S-Video, component video ( NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60 )
Video Output
RGB
Speakers
Speaker(s) - integrated
AC 120/230 V ( 50/60 Hz )
360 Watt
32.7 cm x 39.3 cm x 13.9 cm
6.3 kg
3 years warranty
DLP projector - HD 720p
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3100 lumens
Contrast Ratio
1800:1
Image Size
196 cm - 254 cm
Projection Distance
0.148 m - 0.311 m
Throw Ratio
0.3:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
85 Hz x 91.1 kHz
Bulb type
280 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
6-segment colour wheel, wall colour correction, BrilliantColor, DLP 3D Ready, VIDI Lighting Technology
Lens
Zoom Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-15 / +15
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Input Device
External
1 x VGA input - 15 pin D-Sub (DB-15) , 1 x VGA output - 15 pin D-Sub (DB-15) , 1 x composite video input - RCA , 1 x HDMI input , 1 x S-video input - 4 PIN mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) ( management ) , 1 x network - RJ-45 ( management )
Wall mounting kit, remote control
1 x VGA cable - 3 m
Security Features
Plug and Play, TUV GS, RoHS, EuP Ready
Nominal Voltage
360 Watt
Power Consumption Operational (Standby)
0.5 Watt
32.7 cm
39.3 cm
13.9 cm
6.3 kg
3 years warranty
Service & Support Details
EMEA warranty - 3 years , EMEA warranty - lamp - 6 months / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
36 dB
32 dB
