BT.com
Wishlist
NEC Replacement lamp for NP305
Clearance
£246.25
Clearance
Price Drop
Last Few Remaining
Price Drop! Was £164.53 inc VAT!
5 in stock
£246.25
Add to wishlist
Delivery
Standard 3-5 working days
Spare lamp for NP510/410/405/310/305 projectors.
NEC NP14LP - projector lamp
Projector lamp - 180 Watt
Bulb life cycle
4000 hour(s) (standard mode) / 5000 hour(s) (economic mode)
NEC NP305, NP310, NP405, NP405 EDU, NP410, NP410 EDU, NP510
Projector lamp
Lamp
180 Watt
Life Cycle
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been used and shows signs of use
Ref: 69SR 034701
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£35.35
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
