BT.com
Wishlist
NEC P403 40" Full HD 1920 x 1080 HDMI Black LED Display
NEC P403 40" Full HD 1920 x 1080...
£1,454.11
£1,454.11
Add to wishlist
Delivery
Standard Due date unavailable
The slimmer, lighter MultiSync P403 is packed with additional features that make it the ideal professional choice for any 24/7 retail, transportation, corporate or control room applications that demand trusted performance, flexibility and lower costs of operation.
Connectivity and sensors allow additional creativity in the content displayed and how it is controlled. The unique built-in NFC sensor in combination with NEC's Android app reduces installation and maintenance times, especially useful on larger installations. The human sensor is aware of proximity based viewer presence and can change brightness, volume, inputs or power the display up or down resulting in added engagement and considerable energy savings over time.
NEC MultiSync P403 P Series - 40" LED display
LED-backlit LCD flat panel display
Diagonal Class
40"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-PVA
LCD Backlight Technology
LED backlight - edge-lit
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class C
245 Watt
Power Consumption (On mode)
101 W
Energy Consumption per Year
148 kWh
92.06 cm x 6.65 cm x 53.22 cm
17 kg
3 years warranty
Energy Class
Class C
245 Watt
101 W
148 kWh
Diagonal Class
40"
Commercial Use
Series
P Series
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS), temperature sensor, NFC sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
Dimensions
Without stand
92.06 cm
6.65 cm
53.22 cm
17 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Contrast Ratio
4000:1
Brightness
700 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
8 ms
NaViSet, Dual Open Pluggable Specification slot
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
300 x 300 mm
Video Features
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
DVI-D input , HDMI input , DisplayPort input , DisplayPort output , VGA input , Remote control input , Serial input , 2 x audio input , 2 x network , USB , Audio output , 2 x speakers output
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2B, VESA DPMS, VESA FDMI, PSB, DDC/CI, RoHS
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80% (non-condensing)
Scroll to top
