BT.com
Wishlist
NEC P401W WXGA LCD 4000 Lumens Projector
Free delivery
Delivery
Standard Due date unavailable
Give your presentations a boost in brightness with the NEC P401W, a widescreen entry level professional installation projector loaded with eco-friendly and advanced technologies. Ideal for corporate boardrooms, higher education classrooms and government training rooms, this model delivers remarkable brightness (4000 lumens) and features built-in wall color correction. The P401W touts an active lens cover, which hides content, mutes audio and lowers lamp brightness to 25%, allowing you to maximize the effectiveness of your presentations.
NEC P401W LCD projector
LCD projector - High Definition 720p
Brightness
4000 lumens
Contrast Ratio
4000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
16.7 million colours
Lens Shift Direction
Vertical
Bulb type
UHP 240 Watt
Bulb life cycle
Up to 4000 hour(s) / up to 6000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video ( NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60 ) , LAN
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
AC 120/230 V ( 50 - 60 Hz )
325 Watt
39.8 cm x 28.2 cm x 11.5 cm
4.1 kg
3 years warranty
LCD projector - HD 720p
Ethernet
Projector
Brightness
4000 lumens
Brightness (Reduced)
2680 ANSI lumens
Contrast Ratio
4000:1 (dynamic)
Image Size
64 cm - 760 cm
Projection Distance
0.7 m - 14.6 m
Throw Ratio
1.3 - 2.2 :1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHP 240 Watt
Bulb life cycle
Controls & Adjustments
Input select, aspect control
Eco-Mode technology, freeze frame, Micro Lens Array (MLA) Technology, High-bandwidth Digital Content Protection System (HDCP), wall colour correction, Crestron RoomView, Geometric Adjustment, DICOM Simulation Mode, Direct Power Off, built-in test pattern
Lens
Focus Type
Manual
Lens Aperture
F/1.7-2.1
Zoom Type
Manual
Zoom Factor
1.7x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Vertical
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x microphone input - mini-phone mono 3.5 mm
Lens cover, wireless remote control
1 x VGA cable - 1.8 m
Security Features
Security lock slot (cable lock sold separately), password protection, security label, keypad lock
FCC Class B certified, UL, TUV GS, cUL, DOC-B, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, EMC, RoHS, UL 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, ERP
Nominal Voltage
325 Watt
Power Consumption Stand by
10 Watt
Software Included
Drivers & Utilities
39.8 cm
28.2 cm
11.5 cm
4.1 kg
Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
5 °C
20 - 80% (non-condensing)
Sound Emission
36 dB
29 dB
Scroll to top
