BT.com
Wishlist
NEC NP4100W WXGA Projector
Delivery
Standard Due date unavailable
Marketing description is not available.
NEC NP4100W DLP projector
DLP projector
Built-in Devices
Stereo speakers
Ethernet
Brightness
5500 lumens
Contrast Ratio
2100:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens
No lens
Lens Shift Direction
Horizontal, vertical
Bulb type
2 x 280 Watt
Bulb life cycle
Up to 2000 hour(s) / up to 3000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, PAL-H)
Digital Video Standard
Digital Visual Interface (DVI)
Video Modes
720p, 1080/60i, 1080/50i
Video Output
RGB
Speakers
Speaker(s) - integrated
Microsoft Certification
Compatible with Windows 7
365 Watt
50.5 cm x 38.5 cm x 19.7 cm
17.5 kg
3 years warranty
DLP projector
Built-in Devices
Stereo speakers
Ethernet
Ethernet
Projector
Brightness
5500 lumens
Brightness (Reduced)
4400 lumens
Contrast Ratio
2100:1
Image Size
102 cm - 1270 cm
Projection Distance
1.42 m - 24.4 m
Throw Ratio
1.78 - 2.35:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
85 Hz x 90 kHz
Bulb type
2 x 280 Watt
Bulb life cycle
Controls & Adjustments
Input select, keystone correction, zoom, focus, lens shift dial (horizontal), lens shift dial (vertical), aspect control
Eco-Mode technology, powered tilt, freeze frame, 6-segment colour wheel, High-bandwidth Digital Content Protection System (HDCP), DynamicBlack technology
Lens
No lens
Focus Type
Powered
Zoom Type
Powered
Keystone Correction Direction
Vertical Keystone Correction
-35 / +35
Horizontal Keystone Correction
-40 / +40
Horizontal Lens Shift
10% / 10%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, component video, composite video, S-Video, DVI, RGB
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
3 Watt
Speakers
2 x right / left channel
Input Device
External
Movement Detection Technology
Infrared
Expansion Slots
1 x CardBus - type II
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x component video input - RCA x 3 , 1 x DVI-D - 24 pin digital DVI , 1 x RGB - BNC x 5 , 2 x audio line-out - mini-phone stereo 3.5 mm , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x network - RJ-45 (management) , 2 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 2 x audio line-in - RCA x 2 , 1 x remote control input - mini-phone stereo 3.5 mm , 1 x remote control output - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B
Lens cover, wireless remote control
1 x remote control cable - 10 m
Plug and Play, TUV GS, RoHS
Nominal Voltage
365 Watt
Power Consumption Operational (Standby)
1 Watt
50.5 cm
38.5 cm
19.7 cm
17.5 kg
Limited warranty - 3 years , Limited warranty - lamp - 6 months
Sound Emission
36 dB
32 dB
Scroll to top
