BT.com
Wishlist
NEC NEC E425 42" Edge LED Display
£555.99
49 in stock
£555.99
Add to wishlist
Delivery
Standard 1-3 working days
The NEC E series, direct backlight, commercial-grade displays, are ideal for education, corporate and other digital signage applications. Compared to previous generation displays, these models’ LED backlighting allows for reduced power consumption, a thinner depth, a smaller bezel and lighter weight. Full HD resolution delivers stunning image quality for a variety of content. These displays also feature a USB player in which video, audio or JPEG picture files can be loaded and played in sequence for signage purposes.
NEC MultiSync E425 E Series - 42" LED display
LED-backlit LCD flat panel display
Diagonal Class
42"
Commercial Use
Yes - digital signage / hospitality
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
S-PVA
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote Control
Standard remote
Energy Class
Class A
Power Consumption (On mode)
69 W
Energy Consumption per Year
101 kWh
96 cm x 7.7 cm x 55.5 cm
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Energy Class
Class A
69 W
101 kWh
Diagonal Class
42"
Commercial Use
Series
E Series
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
96 cm
7.7 cm
55.5 cm
Enclosure Colour
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Image Contrast Ratio
3000:1
Brightness
300 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Response Time
6 ms
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Video Features
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 720, 720 x 400, 1920 x 1080, 1280 x 800
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Equaliser
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
3 x HDMI , USB , Serial input , Audio input , VGA input , Composite video / component video / audio input , Digital audio output (optical)
VGA cable
FCC Class B certified, CSA, UL, C-Tick, cUL, SASO, VESA DPMS, PSB, RoHS, REACH
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Power Consumption Stand by
0.5 Watt
On / Off Switch
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
10 - 80%
Scroll to top
