BT.com
Wishlist
NEC MultiSync V801 80" 1920x1080 8ms VGA DVI DisplayPort LED Large Format Display
NEC MultiSync V801 80" 1920x1080...
£8,952.69
13 in stock
£8,952.69
Add to wishlist
Delivery
Standard 1-3 working days
NEC's 80" V801 commercial-grade large-screen LCD display is ideal for applications requiring considerable screen size such as education facilities, coporate lobbies, board rooms, and retail. This display utilizes LED-backlighting to deliver a slim depth and low power consumption while a full high-definition panel delivers brilliant imagery.
NEC MultiSync V801 V Series - 80" LED display
LED-backlit LCD flat panel display
Diagonal Class
80"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
DICOM Simulated Gamma
Speaker System
2 speakers
Remote Control
Standard remote
Microsoft Certification
Compatible with Windows 7
Energy Class
Class A
Power Consumption (On mode)
212 W
Energy Consumption per Year
310 kWh
60 kg
3 years warranty
Energy Class
Class A
212 W
310 kWh
Diagonal Class
80"
Commercial Use
Series
V Series
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
100
Cooling System
Fanless
Dimensions
Without stand
60 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
5000:1
Brightness
320 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Scheduler Function (with RTC), TileMatrix (10 x 10), Open Pluggable Specification slot
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
VGA input , Composite video input , Component video / RGB input , DVI-D input , DVI-D output , HDMI , DisplayPort , Audio input , Remote control , Serial input , Network , Serial output
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, VESA FDMI, PSB, RoHS
Power Consumption Stand by
1 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
20 - 80%
Scroll to top
