BT.com
Wishlist
NEC MultiSync PA322 31.5" 3840x2160 10ms DVI HDMI DisplayPort 4K IPS LED Monitor
Delivery
Standard Due date unavailable
The 32" MultiSync PA322UHD is the benchmark desktop display for color accurate work, from photography to pre-press to videography. Featuring a UHD resolution (3840 x 2160) IGZO technology IPS-type panel with wide gamut white LED backlight, this display provides almost complete coverage of the Adobe RGB color space while consuming little power. Packed with features, the MultiSync PA322UHD will reliably deliver high quality, accurate images simply and beautifully.
NEC MultiSync PA322UHD - LED monitor - 32"
LED-backlit LCD monitor - 32"
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz, DVI: 30 Hz)
Pixel Pitch
0.18 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
24 ms (typical); 10 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xDVI-D, 2xDisplayPort, 4xHDMI
Speakers
Integrated
Display Position Adjustments
74.5 cm x 30.2 cm x 46.9 cm
20.5 kg
FCC Class B certified, MPR II, CSA, UL, TUV GS, cUL, DDC-2B, MPR III, VESA EDID, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, TCO '06, ERP, EAC
3 years warranty
Display Type
Diagonal Size
32"
Viewable Size
31.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.18 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
24 - 120 Hz
Horizontal Refresh Rate
31.5 - 134 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
176
Backlight Technology
WLED
Picture in picture, ambient light sensor, picture by picture, ErgoDesign, RapidMotion, Digital Uniformity Control (DUC), automatic black level adjustment, Carbon Footprint Meter, Carbon Savings Meter, TORO Design, GammaComp, NaViSet Administrator 2, 3D LUT
74.5 cm x 30.2 cm x 46.9 cm - with stand
20.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
2 x DVI-D , 2 x DisplayPort , 4 x HDMI , 2 x USB 3.0 upstream , 3 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm, 200 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x DisplayPort cable , 1 x Mini DisplayPort cable
Power Supply
Internal
68 Watt
Power Consumption Stand by
5 Watt
Included Software
Drivers & Utilities
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
30 - 80%
Scroll to top
