BT.com
Wishlist
NEC MultiSync PA302 30" 2560x1600 DVI DisplayPort USB LED Monitor
NEC MultiSync PA302 30" 2560x1600...
£1,672.10
£1,672.10
Add to wishlist
Delivery
Standard Due date unavailable
Color accuracy that you can trust. The 30" MultiSync PA302W (white) is the new benchmark desktop display for color accurate applications. The innovative GB-R LED backlight provides 99.3% coverage of the Adobe RGB color space while consuming up to 44% less power than comparable CCFL backlights. MultiSync PA302W will reliably deliver high quality, accurate images simply and beautifully.
NEC MultiSync PA302W - LED monitor - 30"
LED-backlit LCD monitor - 30"
Energy Class
Class C
Energy Consumption per Year
92 kWh
Power Consumption (On mode)
63 W
USB Hub
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 16:10
Native Resolution
2560 x 1600 at 60 Hz
Pixel Pitch
0.25 mm
Brightness
340 cd/m²
Contrast Ratio
1000:1
Response Time
7 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, DisplayPort, Mini DisplayPort
Display Position Adjustments
68.8 cm x 30.16 cm x 46.64 cm
17 kg
Microsoft Certification
Compatible with Windows 7
FCC Class B certified, MPR II, CSA, TUV GS, C-Tick, MPR III, PCBC, PCT, VESA EDID, CCC, TUV Ergo, PSB, DDC/CI, RoHS, ISO 9241-307, ERP
3 years warranty
Display Type
Energy Class
Class C
92 kWh
63 W
Diagonal Size
30"
Viewable Size
29.8"
Built-in Devices
USB Hub
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 16:10
Native Resolution
Pixel Pitch
0.25 mm
Pixel Per Inch
101
Brightness
340 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
50 - 85 Hz
Horizontal Refresh Rate
31.5 - 98.7 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
GB-r LED
Controls & Adjustments
Black level
Picture in picture, CableComp, Rapid Response, AutoBright, picture by picture, TileMatrix, ColorComp, Eco-Mode, TileComp, RapidMotion, integrated cable management, Carbon Footprint Meter, Carbon Savings Meter, TORO Design, 108.6% Adobe RGB colour gamut, 99.3% Adobe RGB colour gamut, GammaComp, 3D LUT
68.8 cm x 30.16 cm x 46.64 cm - with stand
17 kg
DisplayPort , Mini DisplayPort , HDMI , DVI-D (dual link) , 2 x USB upstream , 3 x USB downstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm, 200 x 100 mm
Portrait / landscape mode, quick release mechanism
1 x DisplayPort cable , 1 x DVI cable
Power Supply
Internal
87 Watt
Power Consumption Stand by
1.4 Watt
On / Off Switch
Included Software
NaViSet Administrator 2
Dimensions & Weight Details
With stand - width: 68.8 cm - depth: 30.16 cm - height: 46.64 cm - weight: 17 kg , Without stand - width: 68.8 cm - depth: 8.2 cm - height: 44.68 cm - weight: 10.7 kg
Limited warranty - 3 years
5 °C
35 °C
30 - 80%
Scroll to top
