BT.com
Wishlist
NEC MultiSync P703 70" 1920x1080 8ms VGA DVI-D HDMI DisplayPort LED Large Format Display
NEC MultiSync P703 70" 1920x1080...
£5,587.76
£5,587.76
Add to wishlist
Delivery
Standard Due date unavailable
NEC's 70" P703 sets the standard for rugged 24/7 use in the harshest installation environments. LED edge lighting delivers environmental, economic, and aesthetic impact. With a decreased total cost of ownership, a thinner and lighter cabinet, and customizable connectivity, the P series displays deliver stunning solutions. Every time, this display received a full chassis upgrade with the addition of a second expansion slot, faster processing times, evolved daisy chain performance, and near field communication capabilities.
NEC MultiSync P703 P Series - 70" LED display
LED-backlit LCD flat panel display
Diagonal Class
70"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight - edge-lit
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class A
320 Watt
Power Consumption (On mode)
151 W
Energy Consumption per Year
220 kWh
158.7 cm x 8.69 cm x 9.96 cm
47 kg
3 years warranty
Energy Class
Class A
320 Watt
151 W
220 kWh
Diagonal Class
70"
Commercial Use
Series
P Series
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS), temperature sensor, NFC sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
Dimensions
Without stand
158.7 cm
8.69 cm
9.96 cm
47 kg
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Contrast Ratio
5000:1
Brightness
700 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Pixel Pitch
0.802mm
Response Time
8 ms
NaViSet, Dual Open Pluggable Specification slot
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
DVI-D input , HDMI input , DisplayPort input , DisplayPort output , VGA input , Remote control input , Serial input , 2 x audio input , 2 x network , USB , Audio output , 2 x speakers output
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2B, VESA DPMS, VESA FDMI, PSB, DDC/CI, RoHS
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80% (non-condensing)
Scroll to top
