BT.com
Wishlist
NEC Multisync P242W 24" 1920x1200 DVI HDMI DisplayPort LED Monitor
NEC Multisync P242W 24" 1920x1200...
£752.48
Hurry, only 1 left in stock!
£752.48
Add to wishlist
Delivery
Standard 1-3 working days
The NEC MultiSync P242W delivers outstanding image quality with class-leading ergonomics for demanding professional applications. 15 cm height adjust, DisplayPort connector, digital uniformity control, integrated USB hub and Picture-in-Picture give advanced users all the flexibility and image quality to ensure highest personal productivity. This outstanding display cabinet has won the prestigious iF Design Award.
NEC MultiSync P242W - LED monitor - 24.1"
LED-backlit LCD monitor - 24.1"
Energy Class
Class A
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
16 ms (tr - tf); 8 ms (grey-to-grey)
Colour Support
16.8 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
White
55.68 cm x 22.76 cm x 37.8 cm
10.1 kg
Microsoft Certification
Compatible with Windows 7
FCC Class B certified, MPR II, CSA, UL, TUV GS, C-Tick, GOST, cUL, DDC-2B, MPR III, PCBC, PCT, VESA EDID, CCC, TUV Ergo, PSB, DDC/CI, RoHS, ISO 9241-307, WEEE, ERP, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class A
32 kWh
22 W
Diagonal Size
24.1"
Viewable Size
24.1"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen
Native Resolution
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
50 - 85 Hz
Horizontal Refresh Rate
31.5 - 118.4 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, sharpness, colour temperature, black level
Ambient light sensor, OmniColor, CableComp, Rapid Response, Advanced No Touch Auto Adjust, Intelligent Power Manager (IPM), sRGB colour management, TileMatrix, NaViSet, ColorComp, AmbiBright, Eco-Mode, Overdrive technology, DICOM calibrated, TileComp, RapidMotion, OSD lock, 75% Adobe RGB colour gamut, NaViSet Administrator, automatic black level adjustment, Carbon Footprint Meter, TORO Design
White
55.68 cm x 22.76 cm x 37.8 cm - with stand
10.1 kg
DVI-D , HDMI , DisplayPort , VGA , 2 x USB 2.0 upstream , 3 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm, 200 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x DisplayPort cable , 1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D
Power Supply
Internal
AC 120/230 V
Power Consumption Stand by
1 Watt
Dimensions & Weight Details
Without stand - width: 55.68 cm - depth: 8.5 cm - height: 36.24 cm - weight: 7.4 kg , With stand - width: 55.68 cm - depth: 22.76 cm - height: 37.8 cm - weight: 10.1 kg
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
30 - 80%
Scroll to top
