BT.com
Wishlist
NEC MultiSync P232W 23" 1920x1080 DVI HDMI DisplayPort USB LED Monitor White
NEC MultiSync P232W 23" 1920x1080...
£514.54
Hurry, only 1 left in stock!
£514.54
Add to wishlist
Delivery
Standard 1-3 working days
Professional IPS performance desktop display delivers uncompromising image quality as well as minimizing life-cycle environmental impact. Uniting outstanding color reproduction, class-leading ergonomics, a built-in carbon savings meter, ambient light sensor and IPS performance makes it ideal for creative professionals.
The ideal display is design for all creative professionals, designers, photographers, CAD-CAM, video-editing, finance, precision engineering and industrial applications and anyone who cares about their visual work. This excellent display design has won the prestigious iF design award.
NEC MultiSync P232W - LED monitor - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
USB Hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Silver, light grey
54.4 cm x 22.8 cm x 33.8 cm
9.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
DDC/CI
3 years warranty
Display Type
Energy Class
Class A
34 kWh
23 W
Diagonal Size
23"
Viewable Size
23"
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms
Vertical Refresh Rate
85 Hz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Black level
Ambient light sensor, XtraView+, CableComp, Rapid Response, No Touch Auto Adjust, cable management cover, sRGB colour management, TileMatrix, carrying handle, HDCP, AmbiBright, Eco-Mode, X-Light Pro, TileComp, 71.4% NTSC colour gamut, DisplaySync Pro, Ambix 4, 14-bit 3D lookup table
Silver, light grey
54.4 cm x 22.8 cm x 33.8 cm - with stand
9.2 kg
HDMI , DVI-D , VGA , DisplayPort , 2 x USB upstream , 3 x USB downstream
Mechanical
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x DisplayPort cable , 1 x USB cable
DDC/CI
29 Watt
Power Consumption Stand by
1 Watt
Included Software
Drivers & Utilities, MultiProfiler
Dimensions & Weight Details
With stand - width: 54.4 cm - depth: 22.8 cm - height: 33.8 cm - weight: 9.2 kg
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
Scroll to top
